new RADDS v1.1 arived (32-bit RepRap Arduino-Due Driver Shield)
Posted by angelo
March 17, 2014 06:24AM
Hello community,
have now again RADDS v1.1 for 49,90 EUR (while stocks last).
Willy gets (the inventor and quality inspectors) 5 Euro per sold RAMPS shield.
Bolt receives (who built the firmware and tuned for 32-bit, madness're the best) 3 € per sold RAMPS shield.
Thus, I hope that through your help the acquisition of RADDS Shield continuous quality and speed optimization;-).
I hope that this is now fair for all and all have something like this and everyone benefits.
Thank you for buy it in advance.
Angelo
Edited 1 time(s). Last edit at 03/17/2014 07:58AM by angelo.
RADDS-Shield -> Commercial [max3dshop.org]
Re: new RADDS v1.1 arived (32-bit RepRap Arduino-Due Driver Shield)
March 18, 2014 08:07AM
Hi Angelo, have you tried it on the Udoo?
Can I use the 24v with the Udoo, like you say here "RADDS mit 24 V betreiben"?
smiling smiley
---- "Let me make my move" ----
March 18, 2014 08:26AM
yes you can use it, but you have to sold out the Diode D1.
and then you have to sold 3 ten Diods (4 V und 1,3 Watt).
Please have an atention for the diod direction fom left to right (down, up,down).
Now the arduino Due CPU has 12 Volt. A dc-dc maybe becomes to much temperature to use it 24/7 :-).
For udoo it is better (but not nessesary) to give him seperated (for the quad-core cpu) Voltage OUTPUT: 12V, 2A.
RADDS has two Power Input.
So you can work with two power supply one for 12 Volt and the heatbed with 24 Volt (since up 36 Volt and 16 A) if you like.
The 128 microstepperdriver you can give seperated Power. There are plugged backwards to the Nema 17 ... :-)
Edited 1 time(s). Last edit at 03/18/2014 12:12PM by angelo.
March 25, 2014 07:47PM
Angelo, strange, but I find no tutorial and videos showing RADDS running.
If it exists, then you can show us!
March 26, 2014 03:51AM
Hi Fabricio,
I have an Video with the DUE Board + RADDS and an Hall-O Endstop Hack.
[forums.reprap.org]
[www.youtube.com]
In my private Time I configure a 3D-Printserver with udoo and RADDS.
I have to finished the SD-Card Image for my german reprap friends.
[forums.reprap.org]
Thank you for the advice, to make more Videos with RADDS at Work smileys with beer
I will make some and Post it for you and the community ...
Thank you
Angelo
April 26, 2014 11:55PM
I would like to get a radds v1.1 in the USA if possible. Please contact me at cyrus104@gmail.com
April 29, 2014 05:04AM
hi,
ok I write you an E-Mail.
April 29, 2014 05:21AM
By the way ...
A nice "RADDS v1.1" Video from Brendin:
[www.youtube.com]
Edited 1 time(s). Last edit at 04/29/2014 05:21AM by angelo.
May 03, 2014 12:33PM
hi Angelo ,
is it possible too take the signal befoor the stepperdriver so that i can use external stepperdrivers?
May 04, 2014 09:10PM
Wizzard22: You need to pull the signals out of the Pololu connectors, same as with RAMPS.
That said, note that the logic will be 3.3V, not 5V. Either your drivers will need to be able to accept 3.3V logic, or you will need to convert it to 5V logic with an external board.
May 05, 2014 02:26AM
@ wizzard22
Yes, it is possible.
You have to Bridge the "Microstepperdriver-Socets" and plug the 4-Pin Cable irst to the external driver and then to the stepper.
I use the same principal with my 1/128 Microstepperdrivers.
I will post some of the Microstepperdrivers pics after Work :-)
May 06, 2014 04:43AM
May 07, 2014 07:23AM
Hi Angelo,
thanks for the reply.
Now I have another question.
How mutch ampere can give youre externel drivers and where can I get them?
May 07, 2014 07:26AM
Hi Cefiar,
thanks for your reply to, espeshaly about the reminder of the voltage diverens.
May 07, 2014 07:44AM
You need only the Signal from the Due/RADDS to the Driver (3,3 Volt is ok).
Each Driver has a Powerconector (12/24/36/48 Volt).
You have to customize it with the "blue" Encoders.
May 10, 2014 01:38PM
Hi angelo,
Where can I buy the externe drivers that you use?
An the bridg pcb also? confused smiley
May 18, 2014 06:34PM
I've converted to a: RADDS v1.1, DRV8825, 0.9 degree NEMA 17.
I have a delta printer with Pitch 2, Teeth 20, Steps 32, Steps per rotation 400, so 320 steps per mm.
Two of the motors move at the same rate but one of them is moving slightly slower than the other ones. When I home it at the top all looks good but when I start to drive Z down, the extruder head moves to one side because one motor is slower.
Any thoughts?
Thanks
