Calibrating different stepper drivers March 27, 2014 07:59AM |
Re: Calibrating different stepper drivers March 27, 2014 08:50AM |
Re: Calibrating different stepper drivers March 27, 2014 10:59AM |
Re: Calibrating different stepper drivers March 27, 2014 11:06AM |
Re: Calibrating different stepper drivers March 27, 2014 11:30AM |
This is where its nice to be in open source environment, if you can locate sources for what you have and you can open them you will be able to see exact point(s) where Vref can be measured. Some times if the chip pins are exposed (not bga ones), some stuff could be measured on the chip pin itself, i usually do that but its not advisable in this case because the board is under voltage and if you have a hand slipping you make a short with other pins and kill the chip (did that more than once, after which point started to appreciate a probe with a very sharp nose). Without sources i think try to locate Vref pin from chip datasheet and see where it leads to and find a better and safer place to measure it.Quote
JoeDaStudd
On the boards without the vref point it can be taken from the pot correct?
If you can locate them perhaps its written on them, otherwise you can not directly measure them because a typical multimeter will not measure confidently under 0.3-0.2 ohms. Even if it says it measures to like 0.1ohms resolution, that is for higher values, the error is % and plus 1-2 last digits, and in this case the last digit is probably all there is. Again if you locate sources you could find the value written on the schematic file, or part list. Otherwise there are multimeters that measure resistance in Si, if you have one of those, or maybe some other meter specifically for low resistances you could measure it directly.Quote
JoeDaStudd
Also is there an easy way to identify the Rs on the board?
Dont be sorry about asking questions, or learning, we are all here for that. The only thing worth to be sorry would be NOT doing theseQuote
JoeDaStudd
Thanks for your help and sorry if I'm asking a lot of questions. I want to do the whole 3d printer thing right this time, learning as much about everything as I can (well within reason).
