USB-TTL cable 3.3V or 5V?
January 20, 2010 09:46AM
Hi guys,
Any ideas what the advantages and disadvantages are of a 3.3V USB to TTL cable over a 5V USB to TTL cable, specifically for use with the motherboard V1.2?
Thanks...
Re: USB-TTL cable 3.3V or 5V?
January 20, 2010 05:19PM
afaik motherboard runs at 5v
January 21, 2010 07:35PM
The 5v cable can also be used via bit banging to program raw AVR chips to get them ready for use with the Arduino IDE.
i thought usb spec was for 5v signals ?
January 24, 2010 06:26AM
It is but there are 2 variants of the USB to RS232 serial cable 1 for 5v chips and 1 for 3.3v chips.
If you're prepared to put up with 3.3v you can hack a Nokia CA-42 data cable. There about £2 or $3
February 04, 2010 10:09AM
In order NOT to blow any I/O on your motherboard, use the power supply voltage of the processor. So if your processor is powered with 5V, use 5V. If it is 3.3V, use 3.3V.
If you use the ICL3221 you can use both voltages.
In case you need a ready made RS232-TTL converter, check www.tildesign.nl/rs232.htm for a converter, datasheet of the ICL3221 and a schematic of the converter.
Have fun !
February 05, 2010 08:45AM
"RS232" should mean +/-12V serial
"TTL" should mean 0-5V serial
Is there a term that implies 0-3.3V serial?
February 05, 2010 09:33AM
Technically TTL is 5v, but many modern microcontrollers operate at 3.3v not 5, hence the 2 different types.
I beleive TTL was used because its convenient, changing the context to be TTL meaning ic output drive level.
3.3v is technically LVTTL.
