Extruder motor doesn't turn May 08, 2014 01:22PM |
Re: Extruder motor doesn't turn May 08, 2014 09:12PM |
Re: Extruder motor doesn't turn May 10, 2014 01:34PM |
Re: Extruder motor doesn't turn May 10, 2014 02:25PM |
Re: Extruder motor doesn't turn May 11, 2014 05:41AM |
Re: Extruder motor doesn't turn May 11, 2014 08:06AM |
Re: Extruder motor doesn't turn May 11, 2014 10:28AM |
Re: Extruder motor doesn't turn May 11, 2014 12:15PM |
Re: Extruder motor doesn't turn May 11, 2014 12:55PM |
Re: Extruder motor doesn't turn May 22, 2014 05:06PM |
Re: Extruder motor doesn't turn May 22, 2014 11:57PM |
Re: Extruder motor doesn't turn May 23, 2014 07:33PM |
Re: Extruder motor doesn't turn May 24, 2014 12:26AM |
If you want you can measure the voltage on enable, dir and step (for the last one you do need a scope). Enable needs to be low, and if it is high the driver outputs are off. Dir gives direction, when its 0v it moves one way and when its 5v moves the other. For step you need a scope to view it and it looks like a sort of pwm signal. Also you can measure driver points sleep and reset, normally these are not "command lines", but still need to be high (5v) in order for the driver to operate - if these measure other than ~5v then driver shuts itself down. Be careful to not make any shorts. One probe can always sit on gnd so you need one probe to move around. Have the probe tips sharp and dont slip the hand because again, shorts are easy to get at this size and probably fatal.Quote
petitchti
[...]Do you know how and where I can measure, with an oscilloscope, on the Arduino Mega to check if it is a problem of Host/firmware or Arduino/Ramps? I mean which pin and what signal do I need to have?
Min endstops for all axis are the same, so i suppose you have same mechanical switches on all 3 axes. But if on Z you have optoendstop, then it needs to be different.Quote
petitchti
For the Z homing, here is the config.h file (generated with the configuration tool of the repetier firmware).
petitchti
If I decide to remove the jumpers, or not, is there any line to change on the config.h file except the number of steps per mm?
Re: Extruder motor doesn't turn May 24, 2014 02:40AM |
Re: Extruder motor doesn't turn May 24, 2014 06:35AM |
Re: Extruder motor doesn't turn May 24, 2014 09:11AM |
Re: Extruder motor doesn't turn May 24, 2014 05:09PM |
