Question about 3d printer electronics, power supply August 07, 2014 02:26AM |
Re: Question about 3d printer electronics, power supply August 07, 2014 12:53PM |
Re: Question about 3d printer electronics, power supply August 07, 2014 02:43PM |
Re: Question about 3d printer electronics, power supply August 07, 2014 04:01PM |
Re: Question about 3d printer electronics, power supply August 07, 2014 07:22PM |
Re: Question about 3d printer electronics, power supply August 09, 2014 06:50PM |
Re: Question about 3d printer electronics, power supply August 11, 2014 12:06PM |
sheepdog43
What I actually found I like best when I was using Ramps, was using a small 6 amp power brick for the electronics, and a separate 10amp brick for the bed. The bed power brick died after 8 months, but it was convenient in that I could leave it at home and still print PLA. They are also cheap and if one power supply failed, I could use the other and still print PLA. No down time. In your case, if you never transport your printer, buy a cheap power brick for the electronics and just use the 20amp for your bed. If you just want a single power supply, look into a 30 amp or convert a PC power supply that has 30 amps on the 12v line (important!).
Re: Question about 3d printer electronics, power supply August 11, 2014 01:53PM |
Re: Question about 3d printer electronics, power supply August 12, 2014 01:47AM |
That's all there is to it.Quote
tanner331
So to wire it this way should I connect the 20 amp power supply to the 11 amp input on the ramps and the small power supply to the 5amp input on the ramps, or is there something else I have to do?
Re: Question about 3d printer electronics, power supply August 12, 2014 02:54AM |
Re: Question about 3d printer electronics, power supply August 15, 2014 01:01PM |
Re: Question about 3d printer electronics, power supply August 15, 2014 07:44PM |
Re: Question about 3d printer electronics, power supply August 17, 2014 05:10AM |
Re: Question about 3d printer electronics, power supply August 20, 2014 04:38PM |
As Cefiar mentioned, the grounds are tied together. It can although not necessarily will cause issues with switching power supplies with the regulation circuitry. Now since the arduino has it's own power regulation and most of the remaining load is just resistive heaters, it's probably not a huge deal. But a automotive relay costing a buck or two at any automotive store removes any chance of issues.Quote
sheepdog43
The heated bed runs on a completely separate circuit than everything else. It's easy to run two power supplies like that on a Ramps board.
