Slow heating up on MK3 dual power heat bed![]() September 13, 2014 01:40PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 14, 2014 01:49PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 14, 2014 03:29PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 14, 2014 05:27PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 14, 2014 08:57PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 14, 2014 09:46PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 10:01AM |
It changed because you wanted it to change. Switching from 16 to 14ga should have very minimal effect at 12v/10amps.Quote
sheepdog43
What size wires go to the bed? 16Ga wires are not enough. I used two 16ga and while it worked, it wasn't great. I switched to 14 and while it heated fast,
Then you had a very cheap power supply. A power supply is only going to produce the current that it can produce. It's not like the heated bed can "suck" more power out of the power supply than it can provide. If the bed can consume more than the power supply can produce, then the power supply's overload protection circuitry should kick in.Quote
it eventually killed the PSU because it drew more than the PSU could handle.
If you killed a 20 amp power supply drawing < 20 amps, then it wasn't a 20 amp power supply.Quote
Which is the next issue, 20 amps may not be enough, I killed a few 20amp psu's this way.
It's amazing how 7.3+ amps is able to continuously flow through a RAMPS 5 amp PTC without blowing it. Either the PTC is way out of spec on all the boards, or you're not drawing anything over 5 amps combined. And your fans draw 1/3 amp, EACH?!?!? What are you using, a furnace blower to cool your hot end and/or prints?Quote
4 motors = Nearly 4 amps
Hot end = More than 3 amps
Heated bed = 10-11 amps, some as high as 12 depending on resistance.
Fan = 1/3rd amp ea.
You still have to account for anything else needing power and the fact that China uses their own math for rating power supplies, which is usually about 20 (sometimes 50%) lower than rated, and that you shouldn't run a power supply at peak all the time.
Granted, not everything runs full power all the time, so 20 will get you going, it's not enough.
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 11:58AM |
Cefiar
1. What voltage do you get on the following places with the heatbed off (referenced to Gnd on the PSU input to the RAMPS 11A connector):
a. 11A PSU input to RAMPS?
b. D8 + pin (nearest the 11A connector)?
Cefiar
2. What voltages do you get on the following places with the heatbed on (referenced to Gnd on the PSU input to the RAMPS 11A connector):
c. D8 - pin (the other D8 pin)?
Cefiar
3. What voltages do you get across the connector of the heatbed with the heatbed on, at the heatbed end?
Cefiar
From comparison of 1 and 2, you can see if your PSU is drooping under load (eg: putting out less than 12V).
From the values given by 2 and 3, you should be able to map the rough voltage drops in the circuit, which may help identifying further issues if the PSU is not drooping under load.
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 01:40PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 01:51PM |
.75mm is inbetween 18 and 19 AWG and would be right at the very edge which what you should use. They likely are getting warm if you're running them non stop.Quote
ianmcmill
I am using ordinary ceiling lamp wires (german ones with 3 braided wire). They are 0.75mm² which is like something inbetween AWG 20-21. Maybe they are too thin ?
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 01:56PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 01:57PM |
cdru
ianmcmill
What is the resistance of your bed? The specs claim 1.4-1.6ohms configured for 12v, which is on the higher side for heated beds. That translate into lower power requirements and less heat given off. That, combined with the Al core means the less heat it does produce gets spread around a lot more, as well as radiated more. The metal core is nice as it helps keep even heat and can temper any minor momentary fluctuations in heat...however it takes and more to heat up and to maintain that heat.
Re: Slow heating up on MK3 dual power heat bed![]() September 15, 2014 07:02PM |
Re: Slow heating up on MK3 dual power heat bed![]() September 16, 2014 01:24PM |
Get a better heater. Compared to spec, you're heated bed is producing up to 25% less heat than it's suppose to, and nearly 50% the heat other heated beds (1-1.2 ohm) produce. The Alumnium core acts as a giant heat sink. This works for you when you want even heat for your entire bed...but bad when you're already struggling to get it to temperature let alone maintain it.Quote
ianmcmill
The heatbed has 1.9 ohm resistance. 0.3 more than they say in the datasheet.
Re: Slow heating up on MK3 dual power heat bed![]() September 17, 2014 03:23AM |
Resistance between 1.4 and 1.6 ohm for the 12V
Resistance between 5.0 and 5.4 ohm for the 24V
Re: Slow heating up on MK3 dual power heat bed![]() September 20, 2014 10:24AM |
Re: Slow heating up on MK3 dual power heat bed![]() September 20, 2014 11:35AM |
Re: Slow heating up on MK3 dual power heat bed![]() September 21, 2014 06:33AM |
Re: Slow heating up on MK3 dual power heat bed![]() September 21, 2014 07:13AM |
P55NF06L is how STP55N06L is marked which is the 0.016 - 0.020 Ohm part spec'd out for use and the L at the end means you have the proper Logic Level version of the part, so you have the part that is spec'd for RAMPS 1.4Quote
ianmcmill
The three MOSFETS on my Ramps 1.4 are P55NF06L ; 7SABF ; V6 ; PHL 243. None of the ones you named there. Might this be the bottleneck ?
I insulated the alu plate with a 3mm cork sheet.
I just received my Teensylu v0.8. Gonna give this a shot as soon as I get another hotend.
Re: Slow heating up on MK3 dual power heat bed![]() September 21, 2014 07:22AM |
Re: Slow heating up on MK3 dual power heat bed![]() September 21, 2014 08:09AM |
Re: Slow heating up on MK3 dual power heat bed![]() September 21, 2014 12:24PM |
Re: Slow heating up on MK3 dual power heat bed![]() July 17, 2015 01:53AM |
Re: Slow heating up on MK3 dual power heat bed![]() July 17, 2015 07:20AM |
therippa
Can someone link me to the 14V power supply on ebay (I can't seem to find one that doesn't cost a few hundred bucks)? I'm having the same problem with my Prusa i3. I attached an aluminum plate to the bed and now I can't get it over 80c really.
Re: Slow heating up on MK3 dual power heat bed![]() July 24, 2015 09:11PM |
Re: Slow heating up on MK3 dual power heat bed![]() December 08, 2015 12:19PM |
Re: Slow heating up on MK3 dual power heat bed![]() December 08, 2015 02:33PM |
aFrazatto
What bother me as hell and no one seams to have a good explanation, is why temperature drops to 75º every time the printing fan turns on.
Re: Slow heating up on MK3 dual power heat bed![]() December 08, 2015 02:39PM |
Re: Slow heating up on MK3 dual power heat bed![]() December 08, 2015 03:48PM |
aFrazatto
dc42
Simple: the print cooling fan cools the bed as well as the print.
Sorry but this makes no sense....
If it was so, the temperature wouldn't always be the same and it would make little difference on tall objects.
The temperature ALWAYS drops to 75º :3
Re: Slow heating up on MK3 dual power heat bed![]() December 09, 2015 08:14AM |
dc42
Does the indicated temperature drop immediately the fan turns on, rather than over a period of a minute or more? If so, then that suggests a noise, grounding, or firmware issue.
