Can a "good" stepper motor blow the stepper driver? October 02, 2014 04:21PM |
Re: Can a "good" stepper motor blow the stepper driver? October 02, 2014 08:14PM |
Re: Can a "good" stepper motor blow the stepper driver? October 02, 2014 08:21PM |
Re: Can a "good" stepper motor blow the stepper driver? October 03, 2014 07:58AM |
It may not require movement on your part. A loose connection either at the connector, the wire's crimp to the connector, or even inside the motor could theoretically be enough to cause damage. It's not like steppers are THAT expensive. Get a new one and replace your X axis motor and see if the problem continues. I'd do that after I double checked to make sure all the connections were tight.Quote
s10blazed
I have never moved any of the connectors while it was plugged in.
Re: Can a "good" stepper motor blow the stepper driver? October 03, 2014 08:04AM |
Re: Can a "good" stepper motor blow the stepper driver? October 06, 2014 06:40AM |
