Variable resistor in line with heated bed
Posted by UkIan
October 07, 2014 05:10AM
I'm building a heated bed, it will draw more current than ramps will allow, so I was wondering about the effect of putting either a pot or just a single resistor in series to raise the resistance so I can drive it off ramps. I'm looking at a seven switch, but it would be nice to use the bed now.
The question is;I'm using resistance to make heat, so will the pot or resistor get astoundingly hot? I could work a single series resistor into the heating loop, thereby using its heat, but I sort of prefer the pot idea so I can tune.
Thanks
Ian
Ps, also, how would I choose a suitable pot with a range of 0 to 2 ohms?
Re: Variable resistor in line with heated bed
October 07, 2014 05:14AM
Yes, the resistor will get very hot. As it's not got anywhere to radiate that heat like a heat bed (eg: an Alu or glass plate), it will most likely get hotter than the bed.
October 07, 2014 05:27AM
What do you expect the resistance of the bed to be? Can't you adjust the parameters of the bed design to increase its resistance?
October 07, 2014 06:22AM
Just get an SSR and be done with it.....
October 07, 2014 09:33AM
It needs to be about 1.4ohm if used with RAMPS and half that if with the seven switch. I have a cunning plan though. As I need to halve it, I'm going to have two heating loops in series and just disable one as necessary. I think that will do the trick smiling smiley
October 08, 2014 06:51AM
UkIan
Putting two loops in series would double the resistance. For halfing it, you'd use them in parallel.
That said, when you make a bed yourself there's no reason to do such tricks. Simply calculate wires/tracks properly and you're done. See [reprap.org] and [reprap.org]
October 08, 2014 08:01AM
Yes, I currently have half the resistance I need, so was going to add a second loop in series smiling smiley
I think the trick *is* calculating the values correctly in the first place. I made a mistake somewhere, so I'm actually between where I want to be for direct replacement and where I want to be for more ampage :/
