Wire thickness October 11, 2014 10:21AM |
Re: Wire thickness October 11, 2014 05:09PM |
Re: Wire thickness October 11, 2014 05:33PM |
Re: Wire thickness October 13, 2014 01:44PM |
Why was 16ga "not quite enough"?Quote
sheepdog43
I believe I used 14ga for the bed, 16ga was not quite enough.
Re: Wire thickness October 13, 2014 02:38PM |
cdru
sheepdog43
The advantage of heavier gauge wire is to lower resistance, preventing voltage drop and the wire acting as a heating element. However if you're only using a few feet of wire, the amount of resistance is pretty minimal. 4 feet of 18ga wire running at 10 amps has a voltage drop of .26 volts. 16ga and 14ga have drops of .16 and .10 volts respectively. The 1.6 watts difference between the using 18 or 14 gauges I doubt you could even measure in a real world application. The advantage of smaller diameter is it us usually more flexible as well as lighter, both of which are advantageous when they are moving around.
Re: Wire thickness October 13, 2014 03:46PM |
Re: Wire thickness October 13, 2014 03:48PM |
While getting off topic, for DC I believe it still ultimately comes down to the effective cross sectional area. DC utilizes the entire conductor for carrying current. Now if you were talking about a high frequency AC application, then using a hollow tube would save you money and weight as the skin effect results in almost all of the current to be carried around the surface of the conductor. The only thing using a hollow metal tube for DC would be adding stiffness and expense.Quote
UkIan
Of course you could be really cunning and use a large gauge wire, but make it hollow so it doesn't weigh much
Re: Wire thickness October 13, 2014 03:55PM |
Re: Wire thickness October 14, 2014 06:44AM |
cdru
sheepdog43
