Catalyst Circuit Questions April 10, 2010 03:52AM |
Re: Catalyst Circuit Questions April 10, 2010 08:40AM |
Re: Catalyst Circuit Questions April 10, 2010 09:41AM |
Re: Catalyst Circuit Questions April 10, 2010 12:06PM |
Re: Catalyst Circuit Questions April 11, 2010 02:55AM |
Re: Catalyst Circuit Questions April 11, 2010 03:14AM |
Re: Catalyst Circuit Questions April 28, 2010 04:36PM |
Re: Catalyst Circuit Questions April 29, 2010 02:41AM |
Re: Catalyst Circuit Questions April 29, 2010 05:37AM |
Re: Catalyst Circuit Questions April 29, 2010 10:12AM |
Re: Catalyst Circuit Questions April 29, 2010 10:33AM |
Re: Catalyst Circuit Questions April 29, 2010 11:41AM |
V=I*R (tension in Volts = current in Amps * resistance in Ohms)
Old situation: 12V = I * 10 Ohm ==> I = 1.2A New situation: 12V = I * 6 Ohm ==> I = 2A.So the relay contacts should be able to handle 2 Amps, and your power supply should be able to handle 2 Amps plus whatever current other heaters/motors take from it.
P=V*I (power in Watts = tension in Volts * current in Amps)
Old: 12V * 1.2A ==> 14.4 Watt New: 12V * 2A ==> 24 Watt
Re: Catalyst Circuit Questions April 30, 2010 04:00AM |
Re: Catalyst Circuit Questions April 30, 2010 07:08AM |
Re: Catalyst Circuit Questions April 30, 2010 09:04AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Catalyst Circuit Questions May 01, 2010 06:54PM |
Re: Catalyst Circuit Questions May 02, 2010 10:02PM |
Re: Catalyst Circuit Questions May 03, 2010 03:59AM |
Re: Catalyst Circuit Questions May 03, 2010 04:22AM |
Re: Catalyst Circuit Questions May 03, 2010 05:24AM |
> Glass bead thermistors have a time constant of
> several seconds.
Only when taken between extreme temperatures, when I calibrated my thermistor table the delay was not discernible. Furthermore I think the major time delay is temperature propagation from the heater to the thermistor, not so much in the thermistor itself. But then my thermistor is burried deeply in the heater barrel (excellent thermal contact), so your mileage may vary.
Re: Catalyst Circuit Questions May 03, 2010 07:55AM |
Re: Catalyst Circuit Questions May 03, 2010 09:11AM |
Re: Catalyst Circuit Questions May 03, 2010 09:55AM |
