4 Axis Controller
April 13, 2010 07:03PM
This might be of interest.
VDX
Re: 4 Axis Controller
April 14, 2010 05:30AM
... i'm interested, but ordering from germany isn't clear ...
Viktor
April 14, 2010 07:29PM
This appears to be a special purpose motherboard or daughter card. I do not know what brand of mircocontroller it is based on, but it looks like it simply converts RS485 TTL serial commands into step and direction commands that must still go to stepper driver power boards/chips. It has some very nice sounding pre-installed software to do positive and negative limit stops, acceleration and deceleration, peak velocity, and linear movement and even helical movement in several axes at once.
But basically it does something fairly close to what the Mendel motherboard does. Take gcode commands from a host computer and convert them to stepper steps and directions, and sense limit stops. Sounds like they may do it better, but you will still need all the stepper and extruder driver boards.
Mike
April 14, 2010 08:27PM
It's based on LPC2136/01 microcontroller.
The detail info is here:
www.hwml.com
The communication language is not G-Code, but something similar to what's being used in conventional controllers. And it could talk binary - to save microcontroller's parsing/converting time.
There is a G-Code wrapper relized externally (open source) that currently supports this set:
G0, G1, G2, G3, G4,
G17, G18, G19,
G20, G21, G28,
G61, G61.1, G64,
G80, G81, G82,
G90, G91, G92,
M2, M3, M4, M5, M6, M7, M8, M9,
M30
Aryeh
April 15, 2010 08:29AM
For what it is that's expensive.
