Thinking about getting one of those cheap ebay power supplies?
Posted by DasBasti
November 08, 2014 02:27PM
I took one apart and had a poke around what is inside of the supply.
The look quite decent for the price. So I would say go for it.
[www.kurzschluss-blog.de]
Edited 1 time(s). Last edit at 11/08/2014 04:48PM by DasBasti.
Re: Thinking about getting one of those cheap ebay power supplies?
November 08, 2014 05:28PM
Thanks for taking a close look at that PSu! I've been using the 12V 300W version (which is fanless) of a similar power supply to power my printer for the last 6 months, with no apparent problems.
Was the ripple really as much as 1Vpp? It looks a lot less on the scope trace in your blog entry.
November 08, 2014 10:48PM
If your really lucky you get one that blows up
Other fun faults I have seen:
fan upside down...
fan temperature switch replaced with a wire
case so thin most screws have pulled threw. (leaving metal fragments inside the case)
November 09, 2014 06:55AM
dc42
You are right, it is more like 0.2Vpp. I just had a look at it again, it is indeed only 0.2Vpp
