Current measurement? November 20, 2014 11:00AM |
Re: Current measurement? November 20, 2014 12:30PM |
Re: Current measurement? November 20, 2014 01:07PM |
Re: Current measurement? November 20, 2014 01:59PM |
Stepsticks are four times the resistance of genuine Polulus, so .2Ω, not .02Ω. I = VREF / (8 * RS), or rearranged, the VREF you're looking for for the current rating of your steppers is VREF = I * 8 * RS.Quote
loidor
Right, so what the wiki says and what most of the forum posts I find says is that I should use the formula Current=VREF(8*Rs), and that the Rs value for the Polulu is 0.05Ω, but if it's a Stepstick it's 0.02Ω,
So measure the sense resistor that's on your driver. Orient the board so that the main IC (the square one with 28 pins coming off the 4 sides) has the dotted corner in the top left corner. Along the top look at the 2nd pin from either end. Follow the trace to what is usually the two largest resistors on the board. Those are the sense resistors. Measure either of them to find the resistance. Tolerances will vary, so it may not be exactly .05 or .2 but they should be close enough that it should be one of those two values. If you can't figure it out, post a clear picture of the top of the driver and we can tell you which resistor you need to measure.Quote
and... Well, with all the ebay finds these days it can be a tad bit bothersome figuring out what you've got, since some of them only says "A4988 stepper driver".
Re: Current measurement? November 21, 2014 03:31AM |
Of course it is. Occasional brain fart or something.Quote
cdru
