is RADDS not open source? December 12, 2014 04:00AM |
Re: is RADDS not open source? December 12, 2014 09:42AM |
Re: is RADDS not open source? December 12, 2014 10:24AM |
ekaggrat
I cant seem to find the pcb files for RADDS .. I thought it was open source according to the wiki....
Re: is RADDS not open source? December 12, 2014 01:00PM |
Re: is RADDS not open source? December 15, 2014 02:50AM |
Re: is RADDS not open source? December 18, 2014 01:36PM |
In my understanding open source means the source that was used to make the pcb, the source files, in this case the pcb files, have to be available and open. Not the schematic, not pictures, not instuctions, not links to online stores, but the specific files which were actually used to produce the pcb, meaning exactly the PCB files. And not "on request, but publicly readily available.Quote
cdru
Open Source does not mean that the PCB files have to be available, or even just a circuit board diagram and layout. The schematic is here if you didn't find it already. Duplicate the schematic (shouldn't be too hard...it's mostly just labels) and make your own board layout.
Re: is RADDS not open source? March 30, 2016 02:39PM |
Re: is RADDS not open source? March 30, 2016 05:35PM |
Re: is RADDS not open source? March 31, 2016 07:59AM |
Re: is RADDS not open source? April 01, 2016 07:38AM |
chris33
Open source means that i could go to the wiki grab the pcb layout etch my own circuit and source my own components to make my own and maybe develop it further
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: is RADDS not open source? April 01, 2016 11:44AM |
Re: is RADDS not open source? April 01, 2016 12:42PM |
GroupB
Are you working with some firmware dev to port it to any other firmware out there?
Re: is RADDS not open source? April 01, 2016 03:08PM |
Re: is RADDS not open source? April 01, 2016 03:34PM |
Re: is RADDS not open source? April 01, 2016 09:03PM |
Re: is RADDS not open source? April 01, 2016 09:26PM |
GroupB
then put a premade config.g and edit/add/remove stuff to match your printer, No compile option and reflashing each time you change your config , you just put the new file in your SD card and reset the controller.
GroupB
Its just too bad atmel did not release a sam3x8e Dip/Socket size
Re: is RADDS not open source? April 02, 2016 12:39AM |
Re: is RADDS not open source? April 02, 2016 07:08AM |
dc42
It may not be practical to use them with DIY PCBs unless you have a milling machine, but I don't have a problem with that because PCB prototypes are so cheap to have made now.
Re: is RADDS not open source? July 12, 2017 06:43PM |
Re: is RADDS not open source? July 12, 2017 07:04PM |
Admin Registered: 18 years ago Posts: 14,162 |
