Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 19, 2014 06:40PM |
dc42
btw I wouldn't choose standard RAMPS or any other 8-bit Arduino electronics to run a delta, because the 8-bit processors barely have enough power for this application. I suggest you choose 32-bit electronics.
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 20, 2014 08:24AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 20, 2014 04:06PM |
vreihenThe RepRapPro Duet board is also 32-bit, but the RepRap firmware does not have Delta support beyond a promise by a forum member here to implement Delta support over the next few months.[/quote
Actually, the promise I made was January, so it's weeks not months. But of course, it's still vapourware until I deliver it! The preparatory work is going well and I expect to have the basic delta support working in 1 to 2 weeks from now. You can track the progress in the 'delta' branch of my RepRapFirmware repository in github.
The Duet supports Ethernet and a web interface. Does the Smoothieboard?
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 20, 2014 07:02PM |
vreihen
The Azteeg X5 Mini is a 32-bit board, runs Smoothieware, and sells for $109 USD the last time that I looked. No complaints with mine on a Delta, and it is a very popular option on the Google Deltabot group.
I am partial to Smoothieware on either the Azteeg X5 Mini or Smoothieboard, since the Delta support is mature and was written by a Delta printer designer.....
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 09:32AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 12:59PM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 01:23PM |
calmasacow
Are you using once of the VIKI LCD? how well does it work? Definatley would like to use one of these I dont really see how you can get along without it to be honest.
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 21, 2014 01:42PM |
dc42
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? December 22, 2014 03:29AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 13, 2015 01:31AM |
NoobMan
If you fancy DIY, then this may be an option. You have to draw wiring, but will work with any development board of any kindSort of breadboard style.
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 13, 2015 12:27PM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 13, 2015 01:39PM |
vreihen
I am looking forward to seeing Delta support in RepRapFirmware on the Duet. The lack of Delta support is the only reason why I did not buy a Duet board months ago.....
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:00AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:04AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:31AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 09:48AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? January 14, 2015 10:02AM |
Re: Alternative to RAMPS 1.4 for DELTA printer? Smoothieboard maybe? is there anything else? May 15, 2015 10:29AM |
1/128 Microstepping?Quote
angelo
...DippSwitches MSN1=1 (x2), MSN2=2 (x4) MSN3=3 (x16) for Full 1/2 1/4 1/8 1/16 1/32 1/64 1/128 Microstepping:
[attachment 47110 RADDS_2-Back.jpg]
Does it whine like those DRV8825 at 1/32 does? 1/128 is making me drool here for some stuff but too bad we can't software control these on the fly for corners and certain other things. Now that I really want to see for these printers.
