Issue with dual Z-Axis on Rumba with Marlin firmware
Posted by Greccofly
December 23, 2014 01:05PM
I'm trying currenty to set up my new and first printer an Ortbot with a RUMBA board and A4988 drivers on 24V.
On the board I set the dips for all axis to 1/16 (all ON [111])
I've set up the Z-Axis to two drivers, Z and E2. Within the the firmaware I disabled dual Z-Axis in Configuration_adv.h:
#define Z_DUAL_STEPPER_DRIVERS
and in the pins.h:
#define Z_STEP_PIN         57
#define Z_DIR_PIN          56
#define Z_ENABLE_PIN       62
#define Z_MIN_PIN          33
#define Z_MAX_PIN          32
//to use Z_DUAL_STEPPER_DRIVER in Marlin
#define Z2_STEP_PIN        29
#define Z2_DIR_PIN         28
#define Z2_ENABLE_PIN      39
#define E2_STEP_PIN        29
#define E2_DIR_PIN         28
#define E2_ENABLE_PIN      39
The problem is, that both steppers run with different speeds totaly asyncronous. I discoupled the steppers from the lead-screws. So they run without load. Both A4988 are ajusted to the same current.
I've no further idea what could be the problem and how to proceed.confused smiley
hope anyone of you can help me! I lost the hope to spend my spare time till end of the year to finish the printer and get my first prints. sad smiley
Regards
Andreas
Re: Issue with dual Z-Axis on Rumba with Marlin firmware
December 23, 2014 01:48PM
This isn't the answer you are looking for (and I cannot help you with that) but the Rumba is fully capable of running two stepper motors off one driver. I hooked one motor up to the wire connector and one to the pins and have no problems with my Z axis.
Roy
December 23, 2014 02:42PM
Topic is the A4988 current-limits and thermal topic. I`m affraid to bring it to it's limits.
December 24, 2014 10:10AM
All I am saying is that I don't think you need to worry. Hook both stepper motors to the one Z driver and you will not hit the current limit or over heat.I've had three different printers (two with the Rumba, all with A4988) and hooked both motors to one stepper driver on all of them and never had an issue with the Stepper over heating or missing steps.
December 25, 2014 12:19PM
If you are worried about the current limit of the A4988, then why don't you hook up the 2 Z-motors in series? (Especially given that you are using 24V...)
December 26, 2014 04:37PM
The issue is finally solved:
The rumba board is damaged. The jumpers for the steppers were not ok. So I could not set all chanels to 1/16 (Switch position 111). One chanel was running with 1/16 step and the other with 1/4. I'm allready in contact with the dealer. He will send me tomorrow a new board.
Thanks to all your replies.
Regards
Andreas
May 26, 2016 07:08PM
Were you able to get dual Z steppers to work off one driver? If so can you share how? Possibly upload your firmware as a zip as well? Thank you in advance.
