Controller LCD contrast issue December 28, 2014 11:44PM |
Re: Controller LCD contrast issue December 29, 2014 12:45AM |
Re: Controller LCD contrast issue December 29, 2014 02:26AM |
Re: Controller LCD contrast issue December 29, 2014 02:59AM |
Re: Controller LCD contrast issue December 29, 2014 10:35AM |
Re: Controller LCD contrast issue December 29, 2014 11:36AM |
Re: Controller LCD contrast issue December 29, 2014 12:07PM |
Re: Controller LCD contrast issue December 29, 2014 07:02PM |
Re: Controller LCD contrast issue December 30, 2014 03:22AM |
Re: Controller LCD contrast issue December 30, 2014 02:53PM |
Re: Controller LCD contrast issue January 11, 2015 08:04AM |
Re: Controller LCD contrast issue January 13, 2015 09:16AM |
Re: Controller LCD contrast issue January 13, 2015 01:08PM |
Re: Controller LCD contrast issue January 13, 2015 01:28PM |
Re: Controller LCD contrast issue January 28, 2015 01:05PM |
Re: Controller LCD contrast issue March 15, 2015 01:33PM |
Re: Controller LCD contrast issue March 21, 2015 07:36PM |
the_digital_dentist
I just received a RRD GLCD for my Smoothieboard and found the contrast very low whether powered by USB or 12V supply. After checking a bunch of threads like this one I took a closer look at the GLCD module and found that there is a tiny pot on the back side of LCD board mounted near the edge near the backlight. Unfortunately the pot is designed to be adjusted from above, but above is where the controller board is sitting. Unless you're prepared to bend all the pins that connect the two boards together to get at the adjustment you're going to need some tweezers to grip the rotor of the pot and turn it. I did just that and got the display working perfectly regardless of being powered by the USB or 12V supply.
Re: Controller LCD contrast issue May 02, 2015 05:15AM |
Re: Controller LCD contrast issue May 02, 2015 05:49AM |
Re: Controller LCD contrast issue June 24, 2015 11:26AM |
Re: Controller LCD contrast issue June 24, 2015 02:19PM |
Re: Controller LCD contrast issue July 05, 2015 09:45AM |
Re: Controller LCD contrast issue August 16, 2015 12:21AM |
Re: Controller LCD contrast issue December 19, 2015 12:26PM |
Re: Controller LCD contrast issue December 28, 2015 04:04PM |
Re: Controller LCD contrast issue January 09, 2016 08:01PM |
Re: Controller LCD contrast issue January 31, 2016 12:05PM |
Re: Controller LCD contrast issue February 09, 2016 02:46PM |
Re: Controller LCD contrast issue February 23, 2016 03:33AM |
Re: Controller LCD contrast issue May 01, 2016 11:22AM |
