Pololu -> Is this schema working? May 14, 2010 10:07AM |
Re: Pololu -> Is this schema working? May 16, 2010 10:24PM |
Re: Pololu -> Is this schema working? June 03, 2010 12:23AM |
Admin Registered: 18 years ago Posts: 476 |
Re: Pololu -> Is this schema working? June 03, 2010 12:49AM |
Re: Pololu -> Is this schema working? June 03, 2010 01:25AM |
As you probably know, available free tools used for circuit design and board layout include Kicad, Geda and (free as in beer, not open source) Eagle.|
Re: Pololu -> Is this schema working? June 03, 2010 10:28AM |
Re: Pololu -> Is this schema working? June 03, 2010 05:05PM |
Re: Pololu -> Is this schema working? June 03, 2010 08:32PM |
Re: Pololu -> Is this schema working? June 04, 2010 12:34AM |
Re: Pololu -> Is this schema working? June 04, 2010 08:30AM |
Re: Pololu -> Is this schema working? June 13, 2010 12:17PM |
Re: Pololu -> Is this schema working? June 13, 2010 01:36PM |
Re: Pololu -> Is this schema working? June 13, 2010 04:16PM |
Admin Registered: 19 years ago Posts: 1,791 |
Re: Pololu -> Is this schema working? August 05, 2010 11:14PM |
Re: Pololu -> Is this schema working? August 05, 2010 11:45PM |
Re: Pololu -> Is this schema working? August 06, 2010 04:53AM |
Re: Pololu -> Is this schema working? August 28, 2010 05:25PM |
Re: Pololu -> Is this schema working? August 28, 2010 08:37PM |
Re: Pololu -> Is this schema working? August 29, 2010 05:13AM |
Re: Pololu -> Is this schema working? September 04, 2010 09:19PM |
Re: Pololu -> Is this schema working? September 04, 2010 09:55PM |
Re: Pololu -> Is this schema working? September 10, 2010 01:14PM |
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
RXTX Warning: Removing stale lock file. /var/lock/LCK..ttyUSB0
Java 3D WARNING : reported GLX version = 1.2
GLX version 1.3 or higher is required
The reported version number may be incorrect. There is a known
ATI driver bug in glXQueryVersion that incorrectly reports the GLX
version as 1.2 when it really is 1.3, so Java 3D will attempt to
run anyway.
I searched the Reprap forums and Ubuntu forums and found no answers there. I was not even sure if it is a problem so I moved on.
#define X_STEP_PIN 26 #define X_DIR_PIN 28 #define X_ENABLE_PIN 24 #define X_MIN_PIN 3 #define X_MAX_PIN 2 #define Y_STEP_PIN 38 #define Y_DIR_PIN 40 #define Y_ENABLE_PIN 36 #define Y_MIN_PIN 16 #define Y_MAX_PIN 17 #define Z_STEP_PIN 44 #define Z_DIR_PIN 46 #define Z_ENABLE_PIN 42 #define Z_MIN_PIN 18 #define Z_MAX_PIN 19 #define E_STEP_PIN 32 #define E_DIR_PIN 34 #define E_ENABLE_PIN 30 #define LED_PIN 13 #define FAN_PIN -1 #define PS_ON_PIN -1 #define KILL_PIN -1 #define HEATER_0_PIN 12 #define TEMP_0_PIN 2 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
Re: Pololu -> Is this schema working? September 10, 2010 07:33PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Pololu -> Is this schema working? September 12, 2010 11:18AM |
Re: Pololu -> Is this schema working? September 12, 2010 02:46PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Pololu -> Is this schema working? September 13, 2010 03:50PM |
Re: Pololu -> Is this schema working? September 13, 2010 03:55PM |
Re: Pololu -> Is this schema working? September 13, 2010 09:53PM |
Re: Pololu -> Is this schema working? September 13, 2010 10:26PM |
Re: Pololu -> Is this schema working? September 14, 2010 02:38PM |
