Re: SmoothieWare Compatible Mainboards February 06, 2015 07:17AM |
JustAnotherOne
So having something that runs on 8 and 32 bit is unrealistic. It might be possible, but it then can not be high performance on both chips.
JustAnotherOne
Especially as I haven't seen Teacup run on anything 32bit.
dc42
Likewise, printers running Duet electronics sound smoother since I changed the firmware from using the Bresenham algorithm to calculating the step times precisely (to about the nearest microsecond) - for example, see [forums.reprap.org]. The limiting factor in achieving this is the time taken to calculate the square root of a 64-bit number, which needs to be done for every step during the acceleration and deceleration phases.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: SmoothieWare Compatible Mainboards February 06, 2015 10:18AM |
Traumflug
JustAnotherOne
Uhm. You don't really mean this, do you? The whole world is full of software which runs on various bit-widths from the same source code. Changing that is just a matter of a compiler flag. For MCUs also a matter of adjusting to timer names, interrupt names and such stuff, but that's it.
Traumflug
JustAnotherOne
Here you go: [reprap.org]
Traumflug
dc42
Sounds even smoother than "smoother". Teacup demonstrates how acceleration calculations need no 64-bit square roots and also doesn't need to calculate that between every step. Doing this calculation 500 times a second is entirely sufficient to comply with physics. This gives you something like 10'000 clock cycles per calculation, plenty of time.
Traumflug
Maybe it's time to combine these two.
Re: SmoothieWare Compatible Mainboards February 07, 2015 06:27AM |
JustAnotherOne
On 8 Bit you can do a very efficient ring buffer by making it 256 Bytes in size. This way you can always do a ++ on the read and write pointers. The same on 32 bits would ask for a 4GB Buffer.
JustAnotherOne
The AVR has problems when doing multiplication on 16 bit variables. The 32 bits also come with hardware floating point,...
JustAnotherOne
May I cite what that page is saying:
"This page describes something which is no longer the most recent version. For the replacement version see: Gen7 Board-AVR 1.5"
Do I have to say more?
JustAnotherOne
But I can understand your decision if going on ARM was just changing the compiler switch and doing a search and replace on the timer names,..
JustAnotherOneQuote
Traumflug
dc42
You assume here some magic Frequency of 5 MHz. Why?
JustAnotherOneQuote
Traumflug
I don't understand what you want to combine here. But having a discussion about the best algorithms for Step generation, acceleration, jerk,.. would be very interesting. Lets Do that instead of fighting over 8bit vs 32 bits.
Re: SmoothieWare Compatible Mainboards April 24, 2015 06:12AM |
Re: SmoothieWare Compatible Mainboards June 23, 2015 12:59PM |
Re: SmoothieWare Compatible Mainboards June 06, 2018 06:02PM |
Re: SmoothieWare Compatible Mainboards June 07, 2018 11:56AM |
dlc60
(Duet guys, do you want to pitch in more info?
