Are A4982 drivers supposed to be so noisy? March 08, 2015 01:13PM |
Re: Are A4982 drivers supposed to be so noisy? March 08, 2015 02:55PM |
Re: Are A4982 drivers supposed to be so noisy? March 08, 2015 03:10PM |
Re: Are A4982 drivers supposed to be so noisy? March 08, 2015 10:05PM |
Re: Are A4982 drivers supposed to be so noisy? March 08, 2015 11:14PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Are A4982 drivers supposed to be so noisy? March 09, 2015 06:29AM |
Re: Are A4982 drivers supposed to be so noisy? March 09, 2015 07:52AM |
Re: Are A4982 drivers supposed to be so noisy? March 09, 2015 11:25AM |
True, I think my point was just that these A4982's are louder (than the only other drivers I have to compare them to) whichever printer I put them in, and from the feedback i've got so far I don't think other people are getting this much noise with A4982's either, so I'm just totally puzzled why I am.Quote
The Y axis is always noisier than X because the base and carriage act as sounding boards.
Re: Are A4982 drivers supposed to be so noisy? March 09, 2015 11:43AM |
Re: Are A4982 drivers supposed to be so noisy? March 09, 2015 12:11PM |
Re: Are A4982 drivers supposed to be so noisy? March 09, 2015 01:03PM |
Re: Are A4982 drivers supposed to be so noisy? March 13, 2017 08:11AM |
Re: Are A4982 drivers supposed to be so noisy? March 13, 2017 11:58AM |
bbogdanmircea
I know this is quite old, but I think I am having a similar problem with a Printrboard that has A4982 and a corexy printer .
It is same as you said upper in the posts, the carriage is acting like a sound box and is somehow amplifying the noise especially from one driver I think, as I set the infill to go alternatively between drivers, one of them is generating much more noise and resonance in the carriage than the other .
The question is how to fix it, I dialled up the VREF to 1.45 V but the drivers were very hot, but the vibrations seemed to be less but not completely gone .
Tried different bushings and bearings for the carriage trying to fix a mechanical problem but no fix .
I think in corexy is even worse as the belts work together so they can create also some kind of resonance between the motors which makes things only worse ...
I've order a chinese RAMPS as that is modular with A4988 s with radiators, I am willing also to try the DRV8825 or whichever driver go on the RAMPS and are quieter, if you have some ideas let me know .
Steps per mm is around 81, this is with GT2 and 20 teeth pulley, can somebody tell what microstepping are hardwired in the Printrboard ?
Re: Are A4982 drivers supposed to be so noisy? March 14, 2017 06:23AM |
