Blown Mega2560 or? April 03, 2015 10:24AM |
Re: Blown Mega2560 or? April 03, 2015 10:46AM |
Re: Blown Mega2560 or? April 03, 2015 11:02AM |
Re: Blown Mega2560 or? April 03, 2015 12:29PM |
AndersE
I had been running the ramps1.4 on 13.5V as i really think it would be safe as the regulator on Mega states max 15v input. All diodes mounted on ramps.
Re: Blown Mega2560 or? April 03, 2015 02:44PM |
AndrewBCN
13.5V on RAMPS 1.4 = bad idea. The RAMPS 1.4 is designed for 12V operation.
Re: Blown Mega2560 or? April 03, 2015 08:48PM |
RepRap.org wiki
The safest way to power a RAMPS board is to just supply it with 12 volts, which is an easy voltage to generate. This will avoid you frying things that shouldn't be fried by trying higher voltages than are really needed.
Arduino website
The board can operate on an external supply of 6 to 20 volts. If supplied with less than 7V, however, the 5V pin may supply less than five volts and the board may be unstable. If using more than 12V, the voltage regulator may overheat and damage the board. The recommended range is 7 to 12 volts.
Re: Blown Mega2560 or? April 04, 2015 04:08AM |
Re: Blown Mega2560 or? April 04, 2015 11:09AM |
