MKS base 1.2 and auto bed leveling April 12, 2015 04:17PM |
Re: MKS base 1.2 and auto bed leveling April 13, 2015 11:37AM |
Re: MKS base 1.2 and auto bed leveling April 14, 2015 02:44AM |
Re: MKS base 1.2 and auto bed leveling April 14, 2015 09:41AM |
Re: MKS base 1.2 and auto bed leveling April 14, 2015 03:26PM |
Re: MKS base 1.2 and auto bed leveling April 14, 2015 03:44PM |
Re: MKS base 1.2 and auto bed leveling April 14, 2015 05:00PM |
Re: MKS base 1.2 and auto bed leveling May 24, 2015 11:04AM |
Re: MKS base 1.2 and auto bed leveling May 25, 2015 05:06PM |
Re: MKS base 1.2 and auto bed leveling May 30, 2015 11:29AM |
Re: MKS base 1.2 and auto bed leveling June 01, 2015 01:06AM |
legozebra
Everything works now on my Aurora Prusa i3 (MKS_BASE_Ver1.1). The fix was with Cura and changing my start.gcode to include:
G28 X0 Y0 ; Forces X and Y axis zeroing
G29 ; Does the Z-Axis Auto-bed leveling routine
Also remember to check other start.gcode and end.gcode commands as some of the defaults can mess you up either before after your object has printed.
[www.youtube.com]
Thanks Laazrus (and indirectly cdru for suggesting X_MAX_PIN to replace the lack of a PWM SERVO0_PIN) The MKS_BASE_Ver 1.1 seems to have enough power off of X_MAX_PIN to drive the servo with no add'l power source... Though I picked up a 12VDC to 5VDC converter just-in-case (didn't use it in the end) as my single 12VDC power supply has multiple 12VDC power outputs. One oddity I'm trying to figure out is that if I power off the printer with the Z-Axis too high up, when I kick off the next job, the auto-bed leveler never goes down far enough to touch the bed. Right now easy fix is to simply remember to do the "AutoHome" off the Marlin menu if I turned the printer off without re-zeroing..
Re: MKS base 1.2 and auto bed leveling February 28, 2016 03:50PM |
Re: MKS base 1.2 and auto bed leveling December 12, 2017 02:44AM |
