Re: New MKS SBASE Smoothieware-compatible board from China August 06, 2015 12:22AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 06, 2015 08:47AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 07, 2015 12:52AM |
Viper97
Boxcar
flyway97
1. take off component D5 and F3;
2. Connect R-78E-5.0's 3 pins to the 3 solder joints as shown in the picture,
(pin1 to label 1, pin2 to label 2, pin3 to label 3),then it can work well.
Thank you! My MKS SBASE should show up in a week or so. I ordered a few R-78E5.0-1.0 from Digikey so I'll report back once I have everything setup.
Post a how to for us old timers with feeble eye sight. Please?
Re: New MKS SBASE Smoothieware-compatible board from China August 07, 2015 02:50AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 07, 2015 04:50PM |
Re: New MKS SBASE Smoothieware-compatible board from China August 07, 2015 08:21PM |
flyway97
Re: New MKS SBASE Smoothieware-compatible board from China August 08, 2015 05:26AM |
Dejay
Damn. I just got my SBase and now I read this.
So you would have to use wires to attach the spots with the legs of the R-78E5.0-1.0 right?
I only found this for like 11€ at a consumer electronics shop (conrad).
Re: New MKS SBASE Smoothieware-compatible board from China August 08, 2015 06:52AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 09, 2015 03:02AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 09, 2015 05:32AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 10, 2015 01:31PM |
Power draw is 100mA at 12V, down to 70mA at 24V without the USB plugged in. Power drops to 47mA at 12V, 40mA at 24V with the USB plugged in.
Re: New MKS SBASE Smoothieware-compatible board from China August 24, 2015 10:20AM |
CapnBry
I was powering it over USB as well with a Raspberry Pi which was powered from a 5V switching regulator hooked to the 12V supply, so theoretically this was already the case. As stated in my initial review, the power usage does drop when you plug it into USB so that's definitely doing something, but it doesn't drop off completely. I'm not sure if that's just quiescent draw of the regulator.
Before I sell it I might try running it on USB power from something else to see if it makes a difference. I can't remember if I ever tried it without it being hooked to USB (i.e. running off the onboard regulator)
Re: New MKS SBASE Smoothieware-compatible board from China September 01, 2015 10:13PM |
Yeah same story. No matter where the power comes from (USB or 12V input) the temperature bounces around by a few degrees at the higher temps (220C) which makes controlling the hotend at temperature impossible.Quote
tarjeik
Did you ever get around to testing if powering the board via USB solves the problem CapnBry? If not I'll wait for the announced 1.1 board update.
Re: New MKS SBASE Smoothieware-compatible board from China September 02, 2015 05:47PM |
Re: New MKS SBASE Smoothieware-compatible board from China September 02, 2015 05:56PM |
Re: New MKS SBASE Smoothieware-compatible board from China September 03, 2015 02:53AM |
Dejay
I think there is a big difference between the Sbase and the Base. The SBASE is smoothieware compatible and has a different (faster) micro controller. So do you have the sbase or the base?
Re: New MKS SBASE Smoothieware-compatible board from China September 06, 2015 01:21AM |
Re: New MKS SBASE Smoothieware-compatible board from China September 09, 2015 08:38PM |
Re: New MKS SBASE Smoothieware-compatible board from China September 09, 2015 11:16PM |
Re: New MKS SBASE Smoothieware-compatible board from China September 10, 2015 06:42PM |
Re: New MKS SBASE Smoothieware-compatible board from China September 10, 2015 06:45PM |
rocketwiz
Also what's with the heatsinks on the 8825's? Shouldn't they be on the (possibly too small) solder vias on the other side?
Re: New MKS SBASE Smoothieware-compatible board from China September 10, 2015 10:19PM |
arthurwolf
rocketwiz
Yes, putting the heatsinks on the top is definitely very bad design, from somebody with no experience in this, who has not even cared to read the datasheet for the drivers ( or understands how they work ). This is the same attitude that caused the temperature problem.
Re: New MKS SBASE Smoothieware-compatible board from China September 10, 2015 11:55PM |
Re: New MKS SBASE Smoothieware-compatible board from China September 11, 2015 04:01AM |
CapnBry
tarjeik
Re: New MKS SBASE Smoothieware-compatible board from China September 11, 2015 04:45AM |
flyway97
arthurwolf : you are right,the heatsinks on the bottom of 8825 is better. But when the chip's temperature too high(up 70), the temperatue on the two side almost the same.
flyway97
Because on the bottom is harmful to Installation board ,
flyway97
a big heatsinks on the top is useful.
flyway97
Before we do this, we have read datasheet and get suggest from TI's engineer(we use drv8825 more than 10k/month not only on 3d board). We have tested, when use the heatsinks the temperature can low almost 5-8 degree than not use it on the same condition. If use fan can get better effect.
In fact we have careful deal with heat dissipation problem. on the pcb design the surface layer and the middle layer of the copper(GND),The area of the copper(GND) is as large as the plate.
Re: New MKS SBASE Smoothieware-compatible board from China September 11, 2015 04:53AM |
Re: New MKS SBASE Smoothieware-compatible board from China September 11, 2015 10:12AM |
Re: New MKS SBASE Smoothieware-compatible board from China September 11, 2015 10:48AM |
o_lampe
@arthurwolf,
I´m wondering if your negative assumptions about "overall bad design" are totally unbiased?
smoothieboard wiki
This is bad Kung Fu
-Olaf
Re: New MKS SBASE Smoothieware-compatible board from China September 11, 2015 11:56AM |
o_lampe
@arthurwolf,
roboprint
Arthur is just protecting his child in every topic related to smoothieboard
For example: [groups.google.com]
Re: New MKS SBASE Smoothieware-compatible board from China September 12, 2015 04:06AM |
