Re: New MKS SBASE Smoothieware-compatible board from China March 23, 2016 10:29AM |
Re: New MKS SBASE Smoothieware-compatible board from China March 24, 2016 06:36AM |
tuxhead
I received my MKS board and the needed XHP connectors yesterday. It was all packed well. I also flashed the board with latest smoothie edge firmware version (no config files copied yet) which went ok. I have few questions about wiring it into my kossel mini build:
- I followed the build guide by blomker industries (mentioned in the reprap wiki) to setup the structure and so wired my tower end stops (x,y and Z) in "NC" config and the z-probe switch to "NO" based on the doc. I am going to use the hotend as z-probe configuration btw. Now the question is how to connect them on the board? I mean which pins needs to be connected on the board terminals? The wiring diagram of MKS guys is not very much clear.
- What are the signal pins besides the steppers drivers on the board are for? Do they needed to be connected as well?
Re: New MKS SBASE Smoothieware-compatible board from China March 25, 2016 05:52AM |
Re: New MKS SBASE Smoothieware-compatible board from China March 31, 2016 10:12AM |
Re: New MKS SBASE Smoothieware-compatible board from China March 31, 2016 02:38PM |
Re: New MKS SBASE Smoothieware-compatible board from China March 31, 2016 02:57PM |
Re: New MKS SBASE Smoothieware-compatible board from China March 31, 2016 10:45PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 01, 2016 05:12AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 01, 2016 08:25AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 01, 2016 12:02PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 01, 2016 11:23PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 02, 2016 05:26AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 02, 2016 09:04AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 02, 2016 05:09PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 10, 2016 05:38AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 10, 2016 06:18AM |
Looks like mine, with new firmware.Quote
chris33
Just powered it up
Re: New MKS SBASE Smoothieware-compatible board from China April 10, 2016 08:03AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 10, 2016 10:13AM |
I've actually used the Mini IR-sensors a while. Works fine. Learned to level my bed properly by now though, so no longer use any sensors etc, but instead use a 4mm alu-plate with 4mm glass on op => it does not need a sensor.Quote
chris33
i don't know about pt100 i got figure out about what abl system i can us whether fsr, proximity sensor or just the standard probe with miroswitch hopefully the fsr kit may work
Re: New MKS SBASE Smoothieware-compatible board from China April 10, 2016 10:24AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 10, 2016 11:00AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 01:14AM |
Can only agree on that.Quote
chris33
Theres a kit with a board converts the fsrs,to be used with a normal endstop and sensitive settings [github.com] yes i agree a true bed level shouldnt need it but im gadget show man i like it when it does calibration it stratifys my ocd to watch it probe the bed and im rubbish at leveling anything and my abl on my i3 done it job for my lazyness lol
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 01:16AM |
Do you use v1.0 or v1.2? Do you use a thermocople?Quote
tuxhead
Has anyone able to get the RRD full graphic display [reprap.org] with this board. I tried enabling these options in the config file:
It would be greatly helpful if someone can post a functioning config for this LCD
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 06:37AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 07:42AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 08:50AM |
I have never seen one like that no matter what version and reviewer said it *is* 1.3 but no matter I just have never seen any with a Ramps style setup for the stepper drivers only ones like Smoothie that is on the board.Quote
chris33
that one in the amazon is sbase v1.2 but it hasn't had the fix applied the fix should have two crystal soldiered on (aint got board to hand bests going to makerbase technology on aliexpress as they have the fix and the seller is kinda helpful more likely language barrier but answered my question straight away, yes i agree it slows down printing maybe if i use it just to get my bed level 1st set up then i probably wont use it, but i maybe transporting the printer around so its there if i need to use it maybe a detachable probe so i only need to use it when i have to, probably latter come to think of it
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 09:00AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 09:58AM |
Oh, brother, lol. This I did not know and with the names so close it is, indeed, confusing. Well, knowing is half the battle...Go Joe! LOLQuote
chris33
i understand they are a very confusing company lol theres a mks Base then theres a mks sbase 32bit controller lol
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 10:54AM |
dintid
tuxhead
Asking as they mention something regarding these configurations on their sales page: [www.aliexpress.com]
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 12:48PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 01:31PM |
