Re: New MKS SBASE Smoothieware-compatible board from China April 11, 2016 01:44PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 14, 2016 06:29AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 14, 2016 10:34AM |
flyway97
Dear everybody,
This is Shelly from Maker Base(MKS),who will deal with MKS products problems here for you . If there are any inappropriate, please feel free to comment.(Or contact me by E-mail. shelly@makerbase.com.cn)
So many friends are easy to get confused on our MKS items.
Let me make a clear explanation here .
Firstly, MKS is our trademark so that our products name will come with MKS.
Our company specializes in design and manufactory on 3D controller boards and software field .
We have one Smoothieware compatible board which is MKS SBASE.
Others are 2560 & ramps integrated compatible boards.
1.MKS BASE V1.4
Good for dual-extruder printer.
2.MKS BASE2 V1.2
Good for metal machine frame printer with excellent anti-interference, with sd card slot.
3.MKS GEN V1.4
Full micro steps ,replace motor drive manually.
4.MKS MINI V1.2
For One-Extruder and no bed printing.
Our company has never opened PCB to anyone ,but there someone counterfeit our MKS items with bad quality, which makes customers suffer a loss. In order to protect your rights and interests, please purchase in our official website and authorized agent. Thanks.
Also, we have many hot sell items, such as MKS TFT touch screen, MKS TMC2100, anti-interference panel, etc.
Welcome to our official online store:
[www.aliexpress.com]
Re: New MKS SBASE Smoothieware-compatible board from China April 16, 2016 11:18AM |
chris33
flyway97
Dear everybody,
1.MKS BASE V1.4
2.MKS BASE2 V1.2
3.MKS GEN V1.4
4.MKS MINI V1.2
hi i was going through the github for the mks sbase v1.2v and you have the datasheet in english with only the setup options of the controller, but the Chinese version has more information in it about configuring delta is it possible to get that translated in english i have put a issue on github about it thanks
Re: New MKS SBASE Smoothieware-compatible board from China April 16, 2016 11:39AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 12:15AM |
Seriously, that is just so over "engineered".Quote
Dark Alchemist
Makes it flat so all of the heating side touches all of the top plate.Quote
the_digital_dentist
I don't understand the question. Why would you sandwich it between two aluminum plates? You're only going to print on the top. Aside from increasing the mass, what would adding a plate to the underside do?
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 12:16AM |
I just got 2 the other week, and is working on setting up the first one. Am working on an Instructables step-by-step for this board and smoothieware basics for it as well. (and a single temperature switch to turn on hotend fan).Quote
hodgeac
Here is a picture of the latest version of the board. I ordered a couple of these to play with directly from Makerbase's Aliexpress store a couple weeks ago.
[drive.google.com]
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 12:19AM |
The 5v/3.3 jumper is for voltage settings for endstops. I only use simple limit-switches, so it doesn't matter in my case.Quote
hodgeac
chris33
flyway97
Dear everybody,
1.MKS BASE V1.4
2.MKS BASE2 V1.2
3.MKS GEN V1.4
4.MKS MINI V1.2
I too would love it if the english datasheet was updated to include all the contents of the Chinese version. I'd like some documentation on the dipswitches that were added to the board at some point as well. Frankly, most of the pictures in the documentation are for an older version of the board. It would be nice to have some update pictures. How about that 5v/3.3v jumper in the bottom right corner? Doesn't exist in earlier versions of the board and isn't in any of the pictures (nor is it documented beyond the board schematics). The newest version of this board needs updated documentation.
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 12:27AM |
I have a shop in Nashville I sent a picture to (they don't do cad drawings at all) who has several shops around the country that sell Mic-6. I just want them to drill, and countersink, the holes as shown in the picture I have attached. Now my one fear is that 1/4in will be too blasted heavy for an I3 to move around and stop so any speed is dead. 1/4in in the dimensions shown will probably weigh about 3-5 pounds but would be very flat. Add the boro glass and the silicon heater and it will weigh in around 7-8 pounds I think.Quote
dintid
Dark Alchemist
the_digital_dentist
I DO get the issue of the thin 2mm heaters being... flimsy with tendencies to warping/bending. Instead of making an overly complicated sandwich, I'd just take a 4mm machined aluminum plate, from somewhere like [www.aluminiumwarehouse.co.uk] and attach a silicone AC heater under it, using the included 3M 368MP tape.
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 01:20AM |
Well, you DO have 2 motors to lift it, and not like Z needs to be super fast. At least your bed doesn't need to go to MAX before going to 0 like Ultimaker 2 style printers.Quote
Dark Alchemist
....1/4in in the dimensions shown will probably weigh about 3-5 pounds but would be very flat. Add the boro glass and the silicon heater and it will weigh in around 7-8 pounds I think.
Oh, I have tried frames, beds, you name it and USPS and UPS always bends whatever it is. If it isn't bent in shipping it will be bent upon delivery (already had 2 broken mailboxes within a year because the USPS driver didn't want to walk 25 feet on a nice day so they stuff my box and break it).
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 01:39AM |
Ahem, NO this is an I3 and this is the heated bed so 1 motor in the Y direction. It isn't going to happen with that amount of weight.Quote
dintid
Dark Alchemist
Seems you need to get a pair of new motors/Drivers if it's too heavy, and you have solved it.
When I order something like that and am not home to recieve it, I choose to have it delivered to parcel-box. Any parcel need a signature here in Denmark, as they are always insured, so postworkers never put them in mailboxes.
... that said, the topic seems to be WAY off from the the purpose of this tread, so maybe we should take this particular discussion somewhere else, and leave this thread for the Sbase board?
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 02:04AM |
dintid
hodgeac
[drive.google.com]
Just hate it doesn't support PT100
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 07:31AM |
I'm actually been waiting for Smoothieboard v2 for ages, but since there's no date or Price, or even anything on wheter they support PT100 sensors, I thought I'd try the Sbase. Seems like a solid board itself and I'll get to try out Smoothieware Almost done wiring up an um2 clone.Quote
hodgeac
dintid
hodgeac
[drive.google.com]
I'm actually going to use one for my laser cutter and one for my cnc. My Mendel90 is still a work in progress, I have an Ultimaker 1.57 I plan on using with it at the moment. Though if I end up really liking smoothie, I might get a proper smoothieboard for it.
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 10:05AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 11:07AM |
innkeeper
This might be a silly question but... i keep seeing the board refered to as CLOSED SOURCE
they post all thier schematics and board layers etc here
[github.com]
and have so since version 1.0 an they keep it up to date.
can someone explain???
I'm not trying to cause issues, i just want to understand.
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 12:30PM |
Don't look to me to define what is and isn't open or closed source as I don't actually give an eff as long as it works.Quote
hodgeac
innkeeper
[github.com]
I hope you get a nice answer, chances are we'll just get a few pages of Dark Alchemist arguing with some people about the definition of the word "source". Or some other silly crap.
Re: New MKS SBASE Smoothieware-compatible board from China April 17, 2016 03:31PM |
dintid
dintid
innkeeper
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 03:42AM |
Yea, I know how it Works. I know quite a good deal of people who start out using Smoothieware by buying one of these relatively cheap Chinese boards and then upgrade to a real Smoothieboard later on, so I do not really believe the Smoothieware project (or the economical side of it) is loosing on this. The people who do not upgrade to real boards propably would not buy one in any case, so no loss here.Quote
arthurwolf
dintid
It's a huge project ( we are not just taking somebody else's design and firmware and selling it, we actually have to do a lot of work, with the community ), and it is making progress. I hope to have some good news soon.
As for price, we aim at trying to keep the v2 at about the same price as v1 ( maybe a tad more ). But you get much more.
Awesome! Looking forward to it. The Chinese Company suggested hooking the amplifier board up to the AUX-1 pins and set it up from there, but I'm far from qualified for this.Quote
arthurwolf
dintid
We sent a free board to somebody that offered to implement that in firmware, I expect it'll be coming soon.
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 03:46AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 04:08AM |
dintid
@arthurwolf
Is the Smoothieboard 2going to have naitive support for Thermocouplers and/or PT100?
Can the current Smoothieboard handle Thermocouplers without an external amplifier?
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 04:23AM |
Awesome, thanks.Quote
arthurwolf
dintid
@arthurwolf
Smoothieboard v1 does not have amplifiers on-board, and v2 will not either.
However, v2 will have an extension board system that will make it very easy to add things like that, with a standard connector and a rich set of extension boards.
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 04:28AM |
dintid
@arthurwolf
Am a bit confused about this, as your documenation states we need an amplifier, but the chinese says I do not need one for their Sbase 1.2 board (and since they are copying yours I'm getting confused)
Note: My question is not about how Thermocouplers or PT100 sensors, nor their respecive amplifiers Works, but wheter or not the Controller boards have build in amplifiers or not (need to state this based on previous experiences)
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 05:56AM |
Which schematic do you use? I'm not "not" believing you, just looking for confirmation. Much of their info is still NOT for the 1.2 but for the old one, which does not support Thermocoupler.Quote
bobc
dintid
@arthurwolf
It's clear from the schematic for SBASE 1.2 that it does not have onboard support for thermocouples. I've learnt to always take the Chinese statements as "25% true", together with translation issues (thermistor vs thermocouple), they are always eager to make a sale, and are more inclined to say "sure, we can do that!" rather than "don't know".
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 09:01AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 02:14PM |
Re: New MKS SBASE Smoothieware-compatible board from Chin April 18, 2016 04:19PM |
Are you 100 sure you are looking at 1.2 schmetaics? The github one is for their old boards which does not support thermocouplers Off the batQuote
bobc
Chris has it, there is an external module which plugs in.
Schematic is here [github.com]
Page 14 shows connector J7, labelled THC. There are 3 signal pins, they go straight to the CPU. There is no amplifier anywhere on the schematic.
The pins on the external module are labelled the same as J7.
Now, you can believe the Chinese guy, but the evidence is enough for me... you will need to buy the module, unless it is included?
The next thing he hasn't told you is that to get thermocouple support in the firmware you may need to write it yourself... maybe Arthur can say if there is already support for MAX31855K .
Re: New MKS SBASE Smoothieware-compatible board from China April 18, 2016 04:28PM |
Just wanted to mention I appreciate your insight although it is at odds with their specs.Quote
bobc
Re: New MKS SBASE Smoothieware-compatible board from Chin April 18, 2016 06:59PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 19, 2016 05:21AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 19, 2016 05:26AM |
The question is really more a:Quote
chris33
MakerBase Technology Co., Ltd. is the correct aliexpress store and above link to the module they sell i messaged the seller and he said yes you can use that module with the mks sbase v1.2
