Re: New MKS SBASE Smoothieware-compatible board from China April 19, 2016 10:09AM |
Oh man, "for normal people." I like that LOL!Quote
dintid
The question is really more a:Quote
chris33
MakerBase Technology Co., Ltd. is the correct aliexpress store and above link to the module they sell i messaged the seller and he said yes you can use that module with the mks sbase v1.2
How to wire it explained for normal people.
How to setup firmware for normal people.
Re: New MKS SBASE Smoothieware-compatible board from China April 19, 2016 02:23PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 19, 2016 08:04PM |
arthurwolf
innkeeper
This might be a silly question but... i keep seeing the board refered to as CLOSED SOURCE
they post all thier schematics and board layers etc here
and have so since version 1.0 an they keep it up to date.
can someone explain???
It's very simple. Whether or not something is Open-Source is determined by the license under which the author allows you to use the design ( the author owns the copyright, so he can determine what you have the right to do, and what you are forbidden from doing, with his intellectual property : that's the license ).
That license is Open-Source, or it is not. Common Open-Source license examples : CC-BY-SA, GBL, MIT, CERN OHL ... Those are the licenses of things like Arduino, Wikipedia, Linux etc ...
A license is a valid Open-Source Hardware license if it matches this definition : [www.oshwa.org]
It's pretty simple really, hope I explained well.
The MKS board is not Open-Source ( even it's creators agree on this ) because it's not released under an Open-Source license.
Re: New MKS SBASE Smoothieware-compatible board from China April 19, 2016 08:50PM |
I believe earlier in this thread they, the creators, do not want this to be open source because they fear it will be copied and sold. You can scan through the pages to see their response if you wish.Quote
innkeeper
arthurwolf
innkeeper
Ok, so.... this seems simple enough - i wonder if it is there intent and they just don't know how....after all there is a bit of a language barrier....
flyway97
Is it makerbase's intent that this board be released under a valid Open-Source Hardware license?
if so, do you need assistance in what to post to release the design in this way?
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 03:33AM |
I think I solved it everyone, I just need to figure out the firmware partQuote
hodgeac
dintid
chris33
Hopefully, they'll email you some relatively complete and accurate info shortly...Cross your fingers. See, this is what we get for buying poorly documented Chinese boards. Honestly, it's still probably worth it for the money saved and the experience earned. But it definitely takes longer to get up and fully running going this route.
AND because they have some super awesome (and cheap) touch-screens like noone else. Been using one on my ramps (TFT28) a while, which I now use on this Sbase 1.2 and ordered an extra (TFT32) for my second Sbase 1.2 board|
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 03:36AM |
dintid
I published my guide to Configuring MKS Sbase v1.2 32-bit Controller basics and intro to Smoothieware.
I have been unable to find anywhere else at all resembling a guide or intro to Smoothieware, not even on Smoothiewares site - command listing is not a guide in terms of normal people usage
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 03:50AM |
Not entirely sure what you ask?Quote
arthurwolf
dintid
[smoothieware.org] ?
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 04:00AM |
dintid
[attachment 76727 temp.jpg]
Just look at that "illustration"... no normal sane people can get anything usefull from that one.
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 04:33AM |
dintid
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 05:07AM |
Yes, solved it, so now I can relay it.Quote
bobc
dintid
You solved it? Well done
When you write the instructable, make sure to put your name on it so you get the credit.
BTW, it's engineers that are normal and sane. Non-engineers are the idiots.
Problem is how the people writing the technical documenations simply just can not relate to anyone without their techncial knowledge. It effectively Locks out the majority of potential users untill someone comes and bridge the basics gap.Quote
bobc
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 01:31PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 20, 2016 02:41PM |
Guess just like any other endstop.Quote
chris33
Wonders how to connect dc42 ir sensor?
Re: New MKS SBASE Smoothieware-compatible board from China April 21, 2016 05:50AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 21, 2016 11:01AM |
Re: New MKS SBASE Smoothieware-compatible board from China April 21, 2016 11:59PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 22, 2016 07:41AM |
tuxhead
Lesson learnt: Always buy the printer parts especially electronics (LCDs) from same vendor coz even the clones are not actually clones, they differ alot.
Re: New MKS SBASE Smoothieware-compatible board from China April 23, 2016 07:12AM |
Alexus12
Hi everybody.
Has anyone connected the servo to the MKS SBase V1.2? Please, give the diagram how to connect the servo to the board physically. I can't find the +5 pin on the board. Only ground.
How to connect the servo with external power supply for the servo to this board?
Re: New MKS SBASE Smoothieware-compatible board from China April 23, 2016 10:27AM |
Out of curiousity / general Desire to learn:Quote
o_lampe
Alexus12
Hi everybody.
Always use a separate 5V supply for the servo. Make sure, the ground is connected to GND on the Sbase and on the servo plug ( black ). Connect the external 5v line only to the ( red?) servo wire.
The yellow or white servo wire is for the sbase signal.
Re: New MKS SBASE Smoothieware-compatible board from China April 23, 2016 12:58PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 23, 2016 09:19PM |
Thank you. I've never used servos (not going to either) and just thought the endstops were designed for this particular kind of useQuote
bobc
It's not the voltage, it's the current. Even a small servo can draw up to 1 Amp, the 5V regulator is only rated for 1Amp, and that also feeds the 3.3V.
Even active endstops only use a few milliamps, so there is no problem powering from the onboard 5V.
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 08:24AM |
OK. I have connected the servo using external power supply. I have connected minus from the power supply both to servo and to ground pin on the MKS SBase. Plus from the power supply was connected to the plus on the servo. The signal wire from the servo was connected to the pin P1.22 on the MKS SBase.Quote
o_lampe
switch.servo.enable true # switch.servo.input_on_command M280 # M280 S7.5 would be midway switch.servo.input_off_command M281 # same as M280 S0 0% duty cycle, effectively off switch.servo.output_pin 1.22 # must be a PWM capable pin switch.servo.output_type hwpwm # H/W pwm output settable with S parameter in the input_on_comand switch.servo.pwm_period_ms 20 # set period to 20ms (50Hz) default is 50HzThen I tried to send the command M280 S5 to the printer using Pronterface. And nothing happens. Maybe I need to use another command? Or maybe I do something wrong?
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 08:40AM |
Alexus12
o_lampe
Next additional strings was added to the config file:
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 09:02AM |
Thanks. I have changed pin 1.22 to pin 1.23 and now have the next result. When I send M280 S5 or other value of S, the servo turns always on the same position. And only one time. If I send M280 command with another S value the servo is not turns. Only when I change the angle manually the M280 command works again and only one time.
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 09:09AM |
Alexus12
The servo model is Graupner DES 586 BB Standard voltage/ Speed.
I mean any Smoothie-based board ) outputs 3.3V signals. Looking at the specs for your servo motor, I doubt that's enough to control it.|
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 09:41AM |
I have not find any special ports for servos, only several pins for self-design. It is strange that there is no ports for servos on the board.Quote
arthurwolf
Smoothie ( aha I nearly wrote "Smoothieboard"I mean any Smoothie-based board ) outputs 3.3V signals. Looking at the specs for your servo motor, I doubt that's enough to control it.
Maybe the MKS SBASE thing has an actual "Servo" port that bumps things up to 5V ? Somebody here knows ?
I have made this. I use J8 port and changed the jumper to 5 V. The result is the same.Quote
chris33
I would of thought you could use the pins on j8 above the leds, also endstops you can change from 3.3v or 5v
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 01:34PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 02:38PM |
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 03:40PM |
You do not need LCD.Quote
tomi01_2000
i have a dead 3d printer buy it from here
the initial motherboard was with problems - problems on axe x,
i changed the mb with a second, same model, from China (new problems - imposible to build a cube of 1 cm - always is making 0.5mm on axe Z) ... imposible to find a firmware/ CMOS able to modify the errors
Now,
i try to change my printer on a smothie system - motherboard. The same mb like BOBC - MKS SBASE v1.2
I have been installed my new motherboard on the computer (no problems with the drivers - all it's seems to be ok ), but when i try to connect my computer, on my printer using com5 ( port Com - Uberclock) , i have no answer from the printer.
Help!
I don't have a screen / lcd for my mb compatible with the motherboard
1.i need a lcd? it is necessary? what lcd i can use it for this motherboard?
2.i try it to make a firmware, with the firmware from the pack - nothing!
Re: New MKS SBASE Smoothieware-compatible board from China April 24, 2016 03:46PM |
