Re: New MKS SBASE Smoothieware-compatible board from China June 08, 2016 05:44PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 10, 2016 04:18PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 10, 2016 11:24PM |
First off, you did not buy from the manufacturer and I have seen 1.3 posted on models (fake) for a long time, so don't be too excited yet! You have a photo?Quote
animoose
I got my board yesterday. It was advertised on ebay as V1.2 (and still is: [www.ebay.com]), but was actually a V1.3 board. I haven't yet hooked it up to my printer, but did connect it over USB, plugged a thermistor in and checked I got some sort of reading from it. Some problems getting the drivers to install on Windows 7 - it now seems to work but displays an error on first connecting.
Re: New MKS SBASE Smoothieware-compatible board from China June 10, 2016 11:58PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 11, 2016 12:08AM |
dintid
animoose
However you must install both drivers AND firmware on an SD/the controller, before you can get any readings.
Ive made an instructables Configuring MKS Sbase v1.2 32-bit Controller basics and intro to you might find usefull.
Re: New MKS SBASE Smoothieware-compatible board from China June 11, 2016 12:19AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 11, 2016 12:22AM |
You can insert them into the posts to make it easier for peopleQuote
animoose
Pictures of the board: top (https://goo.gl/photos/cwp5cbQVYuzV5qPP6), bottom (https://goo.gl/photos/7AYwKY798TJgjfFj6) and an attempt to show the crystal (https://goo.gl/photos/zomHV8Kqseb24gBy6). Sorry for the poor quality pictures.
Re: New MKS SBASE Smoothieware-compatible board from China June 12, 2016 08:48PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 17, 2016 06:36PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2016 12:43AM |
What is a pb?Quote
jmn47
hi everybody
i buy a MKS BASE and a TFT28 screen from china.
did you have a pb with the screen?
i didn't work for me, I have a problem with the display of icons as you can see on the picture.
I tested all firmwares in GitHub and it's the same problem.
The text is good and the first image too.
thanks for you answers
jm
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2016 04:41AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2016 09:46AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: New MKS SBASE Smoothieware-compatible board from China June 18, 2016 10:31AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 22, 2016 11:54PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 22, 2016 11:59PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 23, 2016 12:11AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 23, 2016 01:28AM |
Looks and work great. Especially nice with the new Move icons. Makes more sense.Quote
flyway97
hello friend,
we have released MKS TFT V1.1.4,please visit our github to download and updated.
[github.com]
Re: New MKS SBASE Smoothieware-compatible board from China June 23, 2016 03:47AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 24, 2016 07:38AM |
Re: New MKS SBASE Smoothieware-compatible board from China June 25, 2016 05:57PM |
Re: New MKS SBASE Smoothieware-compatible board from China June 25, 2016 10:18PM |
For TFT28 and 32 I use MKS GithubQuote
chris33
dintid did you use their firmware bin from the mks github or smoothiewares ?
Re: New MKS SBASE Smoothieware-compatible board from China June 27, 2016 02:39PM |
dintid
chris33
For Sbase I use the newest Edge firmware from Smoothieware.
Re: New MKS SBASE Smoothieware-compatible board from China June 28, 2016 12:42AM |
Actually worked fine for me.. I just choose to use the newest firmware I could findQuote
chris33
dintid
chris33
Yeah the mks firmware.bin doesnt work properly
Re: New MKS SBASE Smoothieware-compatible board from China June 30, 2016 01:02PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2016 01:00AM |
What do you mean it doesn't read the endstops?Quote
chris33
well i did have the updated version of the MKS VERSION of the firmware, doesnt read the endstops i put a issue on the github and someone else had the same problem, just need to figure out why i cant update the tft firmware
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2016 03:35AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2016 04:52AM |
That's not what you said.. what you said was: "i did have the updated version of the MKS VERSION of the firmware, doesnt read the endstops"... now you said you used MKS firmware and later you said smoothieware edge.. but which one is causing problems?Quote
chris33
I know it doesnt have soft endstops and i went with the mks firmware as that what was offered on the github. and im on about the endstops which you home too and like i said i used smoothieware edge firmware works fine i just put the problem i had just in case someone searching the problem at least now people will know how to solve the issue
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2016 07:38AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 01, 2016 08:28AM |
I'm not a native english reader. Proper sentences means the world for understanding. Just sorry you don't want to share in an easy to understand way instead of arguing about it.Quote
chris33
your totally reading it wrong you said you used the latest firmware, i said i used the latest mks firmware which doesnt work proper and if you read it proper i have not got the problem no more as im using smoothieware edge so the is a problem with the mks firmware.bin file which i have said that i put a issue on the the github
