Re: New MKS SBASE Smoothieware-compatible board from China October 11, 2016 05:59AM |
flyway97
Hello, this is the PIN port map of MKS Sbase.
Re: New MKS SBASE Smoothieware-compatible board from China October 11, 2016 11:51PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2016 11:01AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 15, 2016 09:49AM |
wetsparks
OK, had a thought and tried M119. It showed Y an Z end stops had 1s to them. So I have 'nc' outed these end stops for now, just in case this was the problem.
No luck, the fault is still there
Re: New MKS SBASE Smoothieware-compatible board from China October 15, 2016 12:59PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 18, 2016 06:13AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 19, 2016 02:18AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 19, 2016 02:25AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 19, 2016 02:29AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 22, 2016 06:40PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 24, 2016 12:41PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 26, 2016 06:44AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 26, 2016 05:53PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 27, 2016 03:48AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 27, 2016 04:37AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 27, 2016 12:35PM |
Re: New MKS SBASE Smoothieware-compatible board from China November 02, 2016 04:12AM |
Re: New MKS SBASE Smoothieware-compatible board from China November 21, 2016 03:31PM |
Re: New MKS SBASE Smoothieware-compatible board from China November 21, 2016 08:41PM |
w3drk
If anyone in the states want one, I'm selling my SBASE v1.2. It's been modded with stable oscillators (I'm the one who discovered the initial issue), and the DRV8825s are forced into fast decay mode to allow the use of low inductance steppers with 24v, so no need to mess with diodes. In my opinion mixed decay on the DRV8825 is useless...
I was using this board on a 24v Kossel 250 with 0.9deg steppers. After modding to fast decay mode it's nice and smooth and no problems with up to 300mm/sec moves...which with 0.9deg steppers is pushing the 100MHz MCU.
Flawless condition and rock solid stable. $50 PayPal shipped anywhere in the US and its yours.
Re: New MKS SBASE Smoothieware-compatible board from China November 22, 2016 11:55AM |
Re: New MKS SBASE Smoothieware-compatible board from China November 27, 2016 10:04AM |
Re: New MKS SBASE Smoothieware-compatible board from China November 27, 2016 01:21PM |
Djrema
w3drk
I'm really disappointed with this board. Everything installed, edge version running and all seems ok but...
Im having horrible, I mean really horrible high pitch noise coming from the motors. Would you mind to share how you forced to fast decay mode?
I suspect is coming from the drivers. Tried different settings, tried 1/16 and nothing.
Has anyone else found a solution for that?
Cheers,
Raph
chris33
well i have mine running at 12v and mine seem ok but I'm use to noise working with cncs all day but i believe its noiser at 24v, theres a mod im sure there is if you google it changing the decay mode
Re: New MKS SBASE Smoothieware-compatible board from China November 27, 2016 05:31PM |
Re: New MKS SBASE Smoothieware-compatible board from China November 27, 2016 06:42PM |
Re: New MKS SBASE Smoothieware-compatible board from China November 27, 2016 06:46PM |
Re: New MKS SBASE Smoothieware-compatible board from China November 28, 2016 06:34AM |
Re: New MKS SBASE Smoothieware-compatible board from China November 28, 2016 08:53AM |
Billi3
Djrema
w3drk
anyone with a physical picture of the cuircit they made for the diodes as im rubbish at looking at diagrams and find it easier to copy form a physical one thanks
Cheers,
Raph
chris33
W3DRK probably used this method, but I think you are looking for this solution, because neither fast decay and mixed decay mode aren't a complete solution...Read through the blog, but take your time (and probably a couple cups of coffee )
To make a long story short one should create a circuit with several 1N5404 or 1N5408 diodes for every axis
Re: New MKS SBASE Smoothieware-compatible board from China November 28, 2016 11:48AM |
w3drk
Re: New MKS SBASE Smoothieware-compatible board from China December 01, 2016 05:20PM |
Re: New MKS SBASE Smoothieware-compatible board from China December 20, 2016 04:42AM |
