Re: New MKS SBASE Smoothieware-compatible board from China October 18, 2017 01:39AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 29, 2017 05:17AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 29, 2017 05:25AM |
diedirk
Anybody got a solution for my problem:
My board powers/functions just fine from the usb connector, but does nothing at all when i try to power it from the port with 12v (tried multiple power supply's and triple checked the polarity) anybody a clue what's wrong?
Thanks guys
Re: New MKS SBASE Smoothieware-compatible board from China January 22, 2018 05:55AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 25, 2018 06:06PM |
Re: New MKS SBASE Smoothieware-compatible board from China January 30, 2018 05:30PM |
Re: New MKS SBASE Smoothieware-compatible board from China February 08, 2018 09:58PM |
Re: New MKS SBASE Smoothieware-compatible board from China February 09, 2018 06:13PM |
Re: New MKS SBASE Smoothieware-compatible board from China February 27, 2018 06:35PM |
-=Delta G2K=-|
Re: New MKS SBASE Smoothieware-compatible board from China March 11, 2018 05:33AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 03, 2018 11:33AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2018 12:52PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2018 01:05PM |
EagleB3
Accidental hangs are usually due to power problems and mutual interference between the cables. So, in order to compare the old and the new controller, it is important to have not only the same mechanics of printers, but also the exact same components, and their location.
Try to rearrange one controller from the new printer to the old one, and put in it the Micro SD from the old controller, renaming the firmware.CUR to the firmware.BIN. Turn on , restart with the reset button and check if the firmware is installed. And THEN check if the new controller hangs in a completely old environment.
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2018 01:12PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2018 01:17PM |
arthurwolf
MKS uses a 100Mhz chip instead of the 120Mhz chip that Smoothieware is written for ( and that is on the Smoothieboard ). This means as time goes by, it's going to be less and less likely for Smoothie firmware to run on MKS. We are already seeing more and more problems as time passes, and we expect as we implement the next set of major features, you won't be able to use the MKS board at all.
*** X-Files music ***
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2018 01:18PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 12, 2018 07:31PM |
arthurwolf
Brazil is on the high-priority "get a reseller there because customs are so crazy" list, but we haven't found anyone so far. Still looking.
Re: New MKS SBASE Smoothieware-compatible board from China October 15, 2018 02:20AM |
arthurwolf
Re: New MKS SBASE Smoothieware-compatible board from China October 15, 2018 04:38AM |
MKSA
arthurwolf
Do you rely on this frequency for timing purpose ?
Re: New MKS SBASE Smoothieware-compatible board from China October 16, 2018 10:41AM |
arthurwolf
MKSA
arthurwolf
No, but Smoothieware currently uses up most of both RAM and CPU ressources on a normal 120Mhz board, so a 100Mhz board is bound to have issues.
This is mostly about how many features have been added year after year/how much the board "does".
He is frustraded with MKS (and he is right!) and for that he wont help any other user with same problem
Re: New MKS SBASE Smoothieware-compatible board from China October 28, 2018 09:10PM |
jmaurin
Arthur, can you tell me from which version support for PT100 and bed leveling was fully implemented? That's the only features that I need.....so I'll try down to this version instead of latest.
Note that author of issue ticket know the problem and possible solution (but Ican't tbe sure, see: [github.com] ), but it doesn't want to helpHe is frustraded with MKS (and he is right!) and for that he wont help any other user with same problem
Re: New MKS SBASE Smoothieware-compatible board from China October 28, 2018 10:09PM |
Re: New MKS SBASE Smoothieware-compatible board from China October 29, 2018 10:51AM |
Keshan
Just wondering if anyone tried to run marlin 2.0 on this board, I spent the day try to make it boot, but with marlin 2.0 compiled and copied to the sd card,
it just won't boot, the firmware.bin always changed to FIRMWARE.CUR, but the control board just won't boot.
Re: New MKS SBASE Smoothieware-compatible board from China October 29, 2018 11:23AM |
Keshan
Re: New MKS SBASE Smoothieware-compatible board from China October 29, 2018 11:33AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 30, 2018 03:28AM |
crussty
Doesn’t look like a lot of documentation on the RRF precompiled binaries. Is this based of the Duet or Maestro branch? Specifically, does it support th new 12864 LCD structure that is evolving for the Maestro?
Re: New MKS SBASE Smoothieware-compatible board from China October 30, 2018 04:23AM |
Re: New MKS SBASE Smoothieware-compatible board from China October 31, 2018 03:36PM |
xelad
Keshan
Yes i flashed mine 2 days ago with it, worked first time. You are copying it manually to the card? Why not upload it with VS, make sure to format the SD Card correctly too, this can behave funny if something is not 100%
Re: New MKS SBASE Smoothieware-compatible board from China January 21, 2019 11:13AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 22, 2019 06:17AM |
