Re: DIY Tiny OLED I2C full graphics controller May 03, 2015 09:05AM |
Re: DIY Tiny OLED I2C full graphics controller May 05, 2015 02:05PM |
I'll probably change that in my copy of Marlin...|
Re: DIY Tiny OLED I2C full graphics controller May 05, 2015 02:43PM |
enif
I did some follow up on Chri's idea of positioning the rotary encoder horizontally on the side instead of vertically on the front...
The first problem to tackle was the horizontal mounting of the encoder. Even though it's possible to buy encoders which are made for this type of mounting, these are not easy to find and I also already still have a good number of vertical ones... So I decided to convert the vertical encoder to become horizontal with tiny 10x14mm PCB and a straight 4-pin header:
Then I adapted the PCB for the horizontal encoder. At the same time I also removed the protection diode of the buzzer, as I realized that these buzzers are not piezo buzzers, but a "active magnetic" buzzer, i.e. an oscillator with a small speaker. I also added the possibility for an optional resistor in series with the buzzer, in case it buzzes too loud or draws too much current.
Here the resulting electronics
and the "finished" tinyOLED display controller (I will eventually publish the frame on thingiverse, but my SCAD file still needs some tidying up)
I really think that Chri's idea makes much sense: it's more intuitive to use, smaller to implement and also (in my case at least) the encoder pushing force is better absorbed by the frame.
Thanks, Chri, for your excellent idea!
PS: The only thing that is still irritating me is changing the feed rate on the status screen: turning up will decrease the feed rate and turning down will increase itI'll probably change that in my copy of Marlin...
Re: DIY Tiny OLED I2C full graphics controller May 05, 2015 02:45PM |
They aren't THAT hard to find: right angle rotary encoders with detent and built in switchQuote
enif
Re: DIY Tiny OLED I2C full graphics controller May 05, 2015 04:59PM |
Re: DIY Tiny OLED I2C full graphics controller May 06, 2015 06:29AM |
Chri
I never tought that a encoder would be so large compaired to the rest of the LCD
Chri
Although i think a original vertical encoder would be better for longtherm stability as it would have a square soldered footprinted compaired to the modified normal that only has a "line" soldering.
Chri
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller May 07, 2015 05:11AM |
Re: DIY Tiny OLED I2C full graphics controller May 07, 2015 05:58AM |
3dMistery
enif, how do I open your files? I don0t have SW that recognize .patch file.
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller May 07, 2015 08:49AM |
Re: DIY Tiny OLED I2C full graphics controller May 07, 2015 08:56AM |
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller May 07, 2015 08:42PM |
Re: DIY Tiny OLED I2C full graphics controller May 08, 2015 12:44AM |
3dMistery
I still have problems-it's not clear where to copy, what to copy and what to replace.
It's really confusing.
Re: DIY Tiny OLED I2C full graphics controller May 08, 2015 11:49AM |
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller May 08, 2015 11:55AM |
xoan
3dMistery
[en.wikipedia.org]
Re: DIY Tiny OLED I2C full graphics controller May 08, 2015 02:42PM |
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller May 08, 2015 05:20PM |
Re: DIY Tiny OLED I2C full graphics controller May 10, 2015 02:09PM |
Re: DIY Tiny OLED I2C full graphics controller May 10, 2015 02:16PM |
Re: DIY Tiny OLED I2C full graphics controller May 23, 2015 11:08PM |
Re: DIY Tiny OLED I2C full graphics controller May 24, 2015 05:36PM |
Re: DIY Tiny OLED I2C full graphics controller June 04, 2015 07:46PM |
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller June 09, 2015 08:08PM |
Re: DIY Tiny OLED I2C full graphics controller June 10, 2015 02:19AM |
Re: DIY Tiny OLED I2C full graphics controller June 10, 2015 05:10AM |
diff --git a/uiconfig.h b/uiconfig.h
index da02325..1e47611 100644
--- a/../../Repetier-Firmware/Repetier/uiconfig.h
+++ b/uiconfig.h
@@ -110,11 +110,11 @@ What display type do you use?
// CD Pin: UI_DISPLAY_RS_PIN
// ST7920 with software SPI
-#define U8GLIB_ST7920
+//#define U8GLIB_ST7920
// SSD1306 with software SPI
//#define U8GLIB_SSD1306_SW_SPI
// SSD1306 over I2C using hardware I2C pins
-//#define U8GLIB_SSD1306_I2C
+#define U8GLIB_SSD1306_I2C
// For the 8 bit ks0108 display you need to set these pins
// UI_DISPLAY_D0_PIN,UI_DISPLAY_D1_PIN,UI_DISPLAY_D2_PIN,UI_DISPLAY_D3_PIN,UI_DISPLAY_D4_PIN,UI_DISPLAY_D5_PIN,UI_DISPLAY_D6_PIN,UI_DISPLAY_D7_PIN
// UI_DISPLAY_ENABLE_PIN,UI_DISPLAY_CS1,UI_DISPLAY_CS2,
@@ -238,7 +238,7 @@ Define the pin
0 = No keys attached - disables also menu
1 = Some keys attached
-#define UI_HAS_KEYS 0
+#define UI_HAS_KEYS 1
/** \brief Is a back key present.
@@ -246,7 +246,7 @@ Define the pin
If you have menus enabled, you need a method to leave it. If you have a back key, you can always go one level higher.
Without a back key, you need to navigate to the back entry in the menu. Setting this value to 1 removes the back entry.
-#define UI_HAS_BACK_KEY 1
+#define UI_HAS_BACK_KEY 0
/* Then you have the next/previous keys more like up/down keys, it may be more intuitive to change the direction you skip through the menus.
If you set it to true, next will go to previous menu instead of the next menu.
@@ -363,12 +363,13 @@ const int matrixActions[] PROGMEM = UI_MATRIX_ACTIONS;
void uiInitKeys() {
#if UI_HAS_KEYS!=0
- //UI_KEYS_INIT_CLICKENCODER_LOW(33,31); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
- UI_KEYS_INIT_BUTTON_LOW(4); // push button, connects gnd to pin
- UI_KEYS_INIT_BUTTON_LOW(5);
- UI_KEYS_INIT_BUTTON_LOW(6);
- UI_KEYS_INIT_BUTTON_LOW(11);
- UI_KEYS_INIT_BUTTON_LOW(42);
+ UI_KEYS_INIT_CLICKENCODER_LOW(33,31); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
+ UI_KEYS_INIT_BUTTON_LOW(35); // push button, connects gnd to pin
+ //UI_KEYS_INIT_BUTTON_LOW(4); // push button, connects gnd to pin
+ //UI_KEYS_INIT_BUTTON_LOW(5);
+ //UI_KEYS_INIT_BUTTON_LOW(6);
+ //UI_KEYS_INIT_BUTTON_LOW(11);
+ //UI_KEYS_INIT_BUTTON_LOW(42);
// UI_KEYS_INIT_CLICKENCODER_LOW(47,45); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
// UI_KEYS_INIT_BUTTON_LOW(43); // push button, connects gnd to pin
@@ -378,12 +379,13 @@ void uiInitKeys() {
void uiCheckKeys(int &action) {
#if UI_HAS_KEYS!=0
- //UI_KEYS_CLICKENCODER_LOW_REV(33,31); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
- UI_KEYS_BUTTON_LOW(4,UI_ACTION_OK); // push button, connects gnd to pin
- UI_KEYS_BUTTON_LOW(5,UI_ACTION_NEXT); // push button, connects gnd to pin
- UI_KEYS_BUTTON_LOW(6,UI_ACTION_PREVIOUS); // push button, connects gnd to pin
- UI_KEYS_BUTTON_LOW(11,UI_ACTION_BACK); // push button, connects gnd to pin
- UI_KEYS_BUTTON_LOW(42,UI_ACTION_SD_PRINT ); // push button, connects gnd to pin
+ UI_KEYS_CLICKENCODER_LOW_REV(33,31); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
+ UI_KEYS_BUTTON_LOW(35,UI_ACTION_OK); // push button, connects gnd to pin
+ //UI_KEYS_BUTTON_LOW(4,UI_ACTION_OK); // push button, connects gnd to pin
+ //UI_KEYS_BUTTON_LOW(5,UI_ACTION_NEXT); // push button, connects gnd to pin
+ //UI_KEYS_BUTTON_LOW(6,UI_ACTION_PREVIOUS); // push button, connects gnd to pin
+ //UI_KEYS_BUTTON_LOW(11,UI_ACTION_BACK); // push button, connects gnd to pin
+ //UI_KEYS_BUTTON_LOW(42,UI_ACTION_SD_PRINT ); // push button, connects gnd to pin
// UI_KEYS_CLICKENCODER_LOW_REV(47,45); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
// UI_KEYS_BUTTON_LOW(43,UI_ACTION_OK); // push button, connects gnd to pin
#endif
Anonymous User
Re: DIY Tiny OLED I2C full graphics controller June 10, 2015 06:05AM |
Re: DIY Tiny OLED I2C full graphics controller June 11, 2015 05:55AM |
Re: DIY Tiny OLED I2C full graphics controller June 11, 2015 06:25AM |
But you would need to have one extra signal for the oled's CS, e.g. you could use one of the I2C signals for that, as long as you don't need the I2C for the EEPROM.|
Re: DIY Tiny OLED I2C full graphics controller June 12, 2015 04:44AM |
Re: DIY Tiny OLED I2C full graphics controller June 12, 2015 12:16PM |
Re: DIY Tiny OLED I2C full graphics controller June 14, 2015 09:55AM |
