DIY Tiny OLED I2C full graphics controller
Posted by enif
Re: DIY Tiny OLED I2C full graphics controller
December 11, 2017 02:12AM
The SCAD file is commented - but I am sorry, no other explanations for it are available.
And I admit that the technique I used here is somewhat untypical for OpenScad: Essentially, each object consists just of two arrays of blocks, the first one are additive blocks, the second one cavities that are to be cut out. A normal "cube" type block consists just of two entries: the origin point and the size. A cylindrical block consist of the origin followed by an array [direction, radius, height] where direction is (-1 for X, -2 for Y, -3 for Z). Finally there are also optional 3rd , 4th and 5th entries in each block which can be used to specify the value of $fn (i.e. the number of corners used to approximate the cylinder), the level of the block (lower levels are generated/subtracted first) and a condition string (allowing blocks to be only generated under certain conditions).
With this information and the comments in the block list you should at least be able to understand the structure of the objects.
While this is a rather efficient way of coding, I am not sure if it is a good starting point for someone just beginning to learn OpenScad. In this case traditional coding with explicit
calls to cube(), cylinder(), translate(), difference(), etc. is probably much easier...
December 29, 2017 03:00AM
enif
As for the I2C problem on the Arduino Due that caused some conflict when activating simultaneously the I2C OLED (using the U8glib I2C routines) and the I2C EEPROM (using Arduino's Wire.h), I have made some progress:
I removed the '//' from the (3 each) commented out statements "//u8g->pin_list[U8G_PI_SET_A0] = 1;" and "// u8g_i2c_stop();" in file U8glib/utility/u8g_com_arduino_ssd_i2c.c :
$diff u8g_com_arduino_ssd_i2c.c.ori u8g_com_arduino_ssd_i2c.c
125c125
<       //u8g->pin_list[U8G_PI_SET_A0] = 1;
130c130
<       // u8g_i2c_stop();
>       u8g_i2c_stop();
134c134
146c146
>       u8g_i2c_stop();
150c150
163c163
>       u8g_i2c_stop();
After recompiling Marlin4Due with this change the Arduino Due the conflict seems resolved and it can now access the I2C EEPROM (after having it activated in Configuration.h of course) while using the I2C OLED display - so far without any problem smiling smiley
I tried this with marlin 2.0 bugfix and ramps_fd_v2 (tinyoled uncommented), but display and eeprom are not working at the same time. Eeprom only is working. Display only is not working, but it is working for a second when i press disconnect and connect in pronterface. then it goes black again.
Does anyone have this working with Due?
July 10, 2018 05:20AM
Hi all,
I've solved the issue for the EEPROM I2C on Arduino Due (RAMPS4DUE project) in a very easy way.
I've simply moved the EEPROM on the 2nd I2C port available on the Due ( SCL1 SDA1) and made few modification on the Marlin4due firmware:
- Connect the EEPROM on the 2nd I2C, dont' forget to add a couple of 1.5K pull up resistors between SCL1 to 3.3v and SDA1 to 3.3v (the pull up resistors are already implemented on the 1st I2C (D20 and D21) of the Due board.
SDA1        3.3V       SCL1
 o--[1.5k]---o          |
             o--[1.5k]--o
- Modify the Configuration.h to add the option for the 2nd I2C, the red one, in the EEPROM section:
#ifdef EEPROM_SETTINGS
  // To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
  #define EEPROM_CHITCHAT // Please keep turned on if you can.
  #define EEPROM_ON_2ND_I2C // EEPROM CHIP ON second I2C for Arduino Due
  #endif
- Now you have to modify the HAL.ccp to add the new option for the 2nd I2C (in few words we have to use wire1 instead of wire to address the EEOROM on 2nd I2C). Replace the lines between the "//eeprom" and "//Timers" and put the below code:
// eeprom
static bool eeprom_initialised = false;
static uint8_t eeprom_device_address = 0x50;
#ifdef EEPROM_ON_2ND_I2C
static void eeprom_init(void) {
	if (!eeprom_initialised) {
		Wire1.begin();
		eeprom_initialised = true;
void eeprom_write_byte(unsigned char *pos, unsigned char value) {
	unsigned eeprom_address = (unsigned) pos;
	eeprom_init();
	Wire1.beginTransmission(eeprom_device_address);
	Wire1.write((int)(eeprom_address >> 8));   // MSB
	Wire1.write((int)(eeprom_address & 0xFF)); // LSB
  Wire1.write(value);
	Wire1.endTransmission();
	// wait for write cycle to complete
	// this could be done more efficiently with "acknowledge polling"
	delay(5);
unsigned char eeprom_read_byte(unsigned char *pos) {
	byte data = 0xFF;
	eeprom_init ();
	Wire1.requestFrom(eeprom_device_address, (byte)1);
	if (Wire1.available())
		data = Wire1.read();
	return data;
#else
		Wire.begin();
	eeprom_init();
	Wire.beginTransmission(eeprom_device_address);
	Wire.write((int)(eeprom_address >> 8));   // MSB
	Wire.write((int)(eeprom_address & 0xFF)); // LSB
    Wire.write(value);
	Wire.endTransmission();
	delay(5);
	byte data = 0xFF;
	eeprom_init ();
	Wire.requestFrom(eeprom_device_address, (byte)1);
	if (Wire.available())
		data = Wire.read();
	return data;
#endif
// Timers
Now you can use both I2C OLED and I2C EEPROM at the same time.
Bye
Edited 1 time(s). Last edit at 07/11/2018 01:30AM by Skytter.
- Geeetech I3 Pro B "Tuning" GT2560 A+ con sesto Stepper Driver e 3 estrusori - Doppio Alimentatore e Scheda Mosfet per l'HeatBed - Dondolo per I3 Pro B - Diamond HotEnd color mixing - Mk8 Extruder 0.2 nozzle.
- TronXY X5S con Ruramps4d in fase di test.
- Progetto "MiniMaker" full stroke 200x200x180 printer in a 300x300x300 cube.
My Thingiverse: [www.thingiverse.com]
September 20, 2018 03:06AM
Can someone please help me patching my marlin I HAVE NO IDEA WHAT PUT WHERE confused smiley
I have1,3" oled
PLEASE
Edited 1 time(s). Last edit at 09/20/2018 03:08AM by mdg1.
September 20, 2018 12:55PM
Please give us more details (and maybe pictures) of what hardware you actually have (display controller, 3D printer controller) and which version of Marlin you are trying to patch.
September 22, 2018 12:23PM
Hi
It is MKS gen 1.4 display is 1.3"
latest version of marlin 1.8.5
S.T.E.V.E - CoreXY 3D Printer - [www.thingiverse.com]
September 23, 2018 02:32AM
What kind of "1.3 inch oled display" do you have? Unfortunately you don't give any more details on that part - which is the crucial one to answer your question....
Did you really build the "Tiny OLED I2C" controller which this thread is about?
If yes, which version of the PCB and which version of the OLED? (Some I2C OLEDs have different pinouts...)
If no, what exactly do you mean when you say "1.3 inch OLED"? Please show some photos of your hardware.
September 23, 2018 03:37AM
Hi
I don t have hardware problem
pins are directly conected to the mainboard same as it is shown in electrical sheme in first post
I just don t know what to put where in marlin diff is a little bit confusing sad smiley
there is no:
dogm_lcd_implementation.h
Edited 1 time(s). Last edit at 09/23/2018 04:04AM by mdg1.
September 23, 2018 07:55AM
mdg1
Are you sure 1.8.5 is your version of Marlin? I coudn't find it. Might 1.8.5 be the version of the Arduino software you are using?
September 23, 2018 10:14AM
I now downloaded the current version 1.1.9 of Marlin and configured it for my TINYOLED on RAMPS. I needed to change the files Configuration.h, Conditionals_LCD.h and pins_RAMPS.h as follows:
diff Configuration.h.ori Configuration.h
*** Configuration.h.ori	2018-09-23 15:49:49.410579191 +0200
--- Configuration.h	2018-09-23 15:51:19.728792937 +0200
*** 1531,1536 ****
--- 1531,1540 ----
  //#define REPRAP_DISCOUNT_SMART_CONTROLLER
+ //#define U8GLIB_SH1106   // used for most 1.3" OLEDs (default for TINYOLED)
+ //#define U8GLIB_SSD1306  // used for most 0.96" OLEDs
+ #define TINYOLED
  // ULTIMAKER Controller.
diff Conditionals_LCD.h.ori Conditionals_LCD.h
*** Conditionals_LCD.h.ori	2018-09-23 15:48:49.055772809 +0200
--- Conditionals_LCD.h	2018-09-23 16:06:14.335230093 +0200
*** 88,93 ****
--- 88,106 ----
      #define SD_DETECT_INVERTED
    #endif
+ #elif ENABLED(TINYOLED)
+   #ifndef U8GLIB_SSD1306   // define U8GLIB_SSD1306 in Configuration.h if not using SH1106 version
+     #define U8GLIB_SH1106 // SSD1306 and SH1106 are similar, but have slightly different horizontal shift
+   #endif
+   #define ULTIPANEL
+   #define NEWPANEL
+   #define ULTRA_LCD
+   #define DOGLCD
+   #define REVERSE_ENCODER_DIRECTION
+   #define REVERSE_MENU_DIRECTION
  #elif ENABLED(OLED_PANEL_TINYBOY2)
*** 244,249 ****
--- 257,263 ----
  #elif ENABLED(miniVIKI) || ENABLED(VIKI2) \
     || ENABLED(ELB_FULL_GRAPHIC_CONTROLLER) \
     || ENABLED(OLED_PANEL_TINYBOY2) \
+    || ENABLED(TINYOLED) \
     || ENABLED(BQ_LCD_SMART_CONTROLLER) \
     || ENABLED(LCD_I2C_PANELOLU2) \
     || ENABLED(REPRAP_DISCOUNT_SMART_CONTROLLER)
diff pins_RAMPS.h.ori pins_RAMPS.h
*** pins_RAMPS.h.ori	2018-09-23 15:45:57.975156042 +0200
--- pins_RAMPS.h	2018-09-23 15:47:03.653857233 +0200
*** 431,436 ****
--- 431,445 ----
          #define LCD_BACKLIGHT_PIN 39
        #endif
+       #define BTN_EN1 31
+       #define BTN_EN2 33
+       #define BTN_ENC 35
+       #define BEEPER_PIN 37
+       #define LCD_SDSS 53
+       #define SD_DETECT_PIN -1
+       #define KILL_PIN -1
      #elif ENABLED(REPRAPWORLD_GRAPHICAL_LCD)
        #define BTN_EN1           64
Edited 1 time(s). Last edit at 09/23/2018 10:22AM by enif.
September 28, 2018 11:28PM
I am trying to build one of these up as well.
Regarding Marlin- is the config file changes listed in the above post the same as the option for this entry for graphics control panels in Configuration.h file?
This is from 1.1.8.
// TinyBoy2 128x64 OLED / Encoder Panel
//#define OLED_PANEL_TINYBOY2
I am not good with code and am having trouble following the files and calls.
thanks in advance
sinneD
Edited 1 time(s). Last edit at 09/29/2018 12:20AM by sinned.
September 29, 2018 03:59AM
No, I don't think OLED_PANEL_TINYBOY2 will work correctly, AFAIK it's not exactly the same. The OLED dislpay will work, but I don't think that the rest will all work. But you can try it.
September 29, 2018 11:19AM
enif-
thanks for the reply. i will do my best with the above edits
EDIT: I used the above edits in a fresh download of 1.1.9. The line numbers were close, not exactly perfect, but not far off.
I do question a couple of lines- in the first part of the diff, you added commented lines for U8GLIB entries? are they needed if they are commented?
my display works but my buzzer doesn't- could be my buzzer, but having the oled and encoder is tops!
*** 1531,1536 ****
--- 1531,1540 ----
+ #define TINYOLED
EDIT 2: turns out its NOT the piezo buzzer, but Marlin config. You have to enable the following lines- ~ line number 1510 to get feedback sound. I can not remember previous versions settings.
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
//  M300 S P
#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
#define LCD_FEEDBACK_FREQUENCY_HZ 5000
you will also have to adjut the frequency and duration to make them audible. I used MS=100 and f=5000
sinneD
Edited 5 time(s). Last edit at 09/30/2018 02:52PM by sinned.
October 27, 2018 02:44PM
Hello
Thank you for sharing.
Where is kill button ?
[elektromanyetix.com]
January 20, 2019 08:18AM
Hi, i hope someone can help me.
I have a anet board and a 0'96 oled on it (sda & scl on LCD pin 8 & 10)
In configuration.h i selected my anet board and defined U8glib_ssd1306, oled works fine.
But my problem is that i have absolutley no idea how i must edit anything for my rotary encoder :/
January 20, 2019 03:58PM
I don't know the Anet board nor how exactly you have connected the encoder and the buzzer to the board.
But what you need to do is in pins_ANET_10.h (or whatever the pins file for your board is) you need to
define the pin numbers for the 3 encoder pins BTN_EN1, BTN_EN2, BTN_ENC and for the buzzer pin BEEPER_PIN.
January 25, 2019 01:54PM
Hello, please can you share the marlin for the sanguinololu that I have been trying for 3 months to connect the oled but the marlin gives me 8mhz errors is the 1.3a card thanks friend mi correo es
Edited 1 time(s). Last edit at 01/25/2019 03:08PM by VDX.
January 26, 2019 08:14AM
juansuarez
Could you please explain your problem more specifically:
- Where do you get "8MHz errors", what is the exact error message and from which program?
- How did you connect you OLED? Pictures?
- Which version of the Tiny OLED do you have? Is it the one described here? or one bought from China? ... or just a bare OLED?
January 26, 2019 08:34AM
re 8 MHz error
I suspect they simply selected the 8 Mhz processor option for the sanguino... vs the 16mhz as it should be.
January 26, 2019 08:35AM
@juansuarez:
Here is how I modified Marlin 1.1.9 for my Tiny OLED on the Sanguinololu:
In Configuration.h add a line "#define TINYOLED" and make sure that you don't have any other display controllers defined.
Apply the following changes in pins_SANGUINOLOLU_11.h:
*** pins_SANGUINOLOLU_11.h.ori	2018-12-04 10:37:15.101313000 +0100
--- pins_SANGUINOLOLU_11.h	2018-12-04 10:47:03.641419000 +0100
*** 262,267 ****
--- 269,285 ----
      #define BTN_EN1             -1
      #define BTN_EN2             -1
+       #ifdef BTN_EN1
+         #undef BTN_EN1
+         #undef BTN_EN2
+       #endif
+       #define BTN_EN1 30  // A1 - rotary encoder A
+       #define BTN_EN2 29  // A2 - rotary encoder B
+       #define BTN_ENC 28  // A3 - rotary encoder push switch
+       #define BEEPER_PIN  10  // RX1 - piezo beeper
+       #define LCD_SDSS 31     // SD Card SS pin
    #else  // !LCD_I2C_PANELOLU2 && !LCD_FOR_MELZI && !ZONESTAR_LCD
      #define BTN_ENC             16
Apply the following changes in Conditionals_LCD.h:
*** Conditionals_LCD.h.ori	2018-12-02 10:30:33.677927000 +0100
--- Conditionals_LCD.h	2018-12-02 10:31:20.713003000 +0100
*** 88,93 ****
--- 88,106 ----
    #endif
+   #endif
+   #define ULTIPANEL
+   #define NEWPANEL
+   #define ULTRA_LCD
+   #define DOGLCD
*** 244,249 ****
--- 257,263 ----
These are only the changes for configuring the Tiny OLED, not including any changes specific to the Sanguinololu and the printer itself.
January 31, 2019 11:06PM
hello thank you all
this problem is the one that I have
const uint16_t table_address = (uint16_t) & speed_lookuptable_fast [(uint8_t) (step_rate >> 8)] [0],
gain = (uint16_t) pgm_read_word_near (table_address + 2);
I am very new with sanguinololu
I have not been able to solve the problem
Thank you
open | download - prueba.png (71.4 KB)
January 31, 2019 11:12PM
Hello
when I upload other programs to sanguinololu there is no problem but with marlin if and I am pointing the plate well the number 62 and the marlin does not generate problem when I choose atmega1284 16mhz but when I choose atmega1284 8mhz if there is
Thank you
February 01, 2019 03:20AM
@juansuarez do not choose 8mhz. the sanguinololu board is 16mhz.
but if you really want to...
look in speed_lookuptable.h
the file consists of a large block of data in a if statement
#if F_CPU == 16000000 // ie 16mhz
const uint16_t speed_lookuptable_fast[256][2] PROGMEM = {
const uint16_t speed_lookuptable_slow[256][2] PROGMEM = {
#elif F_CPU == 20000000 //ie 20mhz
you would need to setup a section starting with
#elif F_CPU == 8000000 //ie 8mhz
with the correct values for the two lookup tables.
use the tool createSpeedLookupTable.py from [github.com]
eg python createSpeedLookupTable.py --cpu-freq 8 --divider 8
But if you don't have a 8mhz Crystal or resonator, it may compile, but it will not work, as the serial baud rates will be at the wrong frequency.
Edited 6 time(s). Last edit at 02/01/2019 04:47AM by Dust.
March 01, 2019 06:32PM
Hello
thank you all and solve the problem
but now I have the following problem when I turn on the bloody shows the logo of marlin and it flashes and it does not show anything but the screen remains dark thanks
