Re: Alligator Board Q & A May 14, 2015 05:09AM |
Re: Alligator Board Q & A May 14, 2015 06:01AM |
Re: Alligator Board Q & A May 14, 2015 07:40PM |
Re: Alligator Board Q & A May 14, 2015 07:59PM |
dc42
It's a shame the Alligator team didn't learn from the Duet (which is also based around the Arduino Due but came out a year earlier) and design the board to use the native USB port as standard. Using the native USB port instead of the USB-over-serial port solves two problems:
- it means that it doesn't matter what you set the baud rate to, because there is no async comms involved;
- it provides higher speed with flow control, which means you can get much better data rates.
But I understand there are issues with the 5V supply on the Alligator native USB port. Maybe they will fix that in a future revision of the board.
Re: Alligator Board Q & A May 15, 2015 04:18AM |
Re: Alligator Board Q & A May 15, 2015 04:35PM |
Re: Alligator Board Q & A May 15, 2015 04:42PM |
Re: Alligator Board Q & A May 16, 2015 04:40AM |
Re: Alligator Board Q & A May 16, 2015 07:58AM |
Re: Alligator Board Q & A May 16, 2015 01:16PM |
Re: Alligator Board Q & A May 17, 2015 10:28AM |
Re: Alligator Board Q & A May 17, 2015 09:52PM |
Re: Alligator Board Q & A May 18, 2015 12:17AM |
Re: Alligator Board Q & A May 19, 2015 03:56AM |
Re: Alligator Board Q & A May 20, 2015 01:49AM |
Re: Alligator Board Q & A May 20, 2015 04:57AM |
Re: Alligator Board Q & A May 21, 2015 12:33PM |
Re: Alligator Board Q & A May 23, 2015 12:33PM |
Re: Alligator Board Q & A May 23, 2015 01:14PM |
Re: Alligator Board Q & A May 23, 2015 06:06PM |
Re: Alligator Board Q & A May 27, 2015 10:15PM |
Re: Alligator Board Q & A May 28, 2015 01:40PM |
Hello,
which camera works well?
is there a way to tune the motors in repetier? I have need of turning down my motors...they are well...hot..
Re: Alligator Board Q & A June 01, 2015 11:59AM |
Re: Alligator Board Q & A June 01, 2015 02:04PM |
Re: Alligator Board Q & A June 01, 2015 02:49PM |
Re: Alligator Board Q & A June 01, 2015 06:12PM |
maralb
MOTOR CURRENT Is PERCENT
exaggerated its setting
#define MOTOR_CURRENT_PERCENT { 250,200,170,230,230}
Re: Alligator Board Q & A June 01, 2015 06:23PM |
JET-A1
Hello,
on Sunday i tried to instal Repetier for Alligator to my naked Board using only the Native USB and Arduino 1.6.3 without 12v Power with no effort ... i tought the native USB Port is only for Progamming, but not even Windows 7 didnt showed up the Alligator ???
I wrote a Mail to Marco and he told me to connect the Board with 12v and program with the UART USB Port. Ok i did what he told me and Windows took the Board as a HS-232 . With Arduino i compiled the Repetier and want to upload ( and yes i cleared the Flash) but Arduino says after compiling , no Device on COM6 ...
What do i wrong ? Is there a Special Windows Driver for Alligator ? I tried Arduino 1.5.8 also ... no effort ...
Ive no Idea how to get the Firmware on the Board
I am very pleased for some Ideas !
Greetings
Re: Alligator Board Q & A June 01, 2015 06:41PM |
theprophet
Hello,
I was wondering if it was normal to put heatsink on the Alligator DR8825 driver? I had to do that because of thermal shutdown if the current is more than 2amps.
Do you also had this issue?
I also have a lot of problem using the Repetier firmware with my custom cartesian printer. But with MarlinKimbra4Due, I don't have any problem so far!
Motor's are loud and vibrate a lot, microstepping doesn't seem to work properly, etc... Any idea?
Thank you!
Mike
Re: Alligator Board Q & A June 02, 2015 01:15AM |
Re: Alligator Board Q & A June 02, 2015 05:33AM |
