RADDS SD card read error
Posted by edwell
June 16, 2015 07:17AM
I have a Tantillus which is controlled by a RADDS board with 0.9 deg steppers and RAPS128 microstepping drivers. I am also using the RADDS LCD (I bought a complete kit)
firmware is Repitier .92
The problem I am having is an intermittent SD read error which kills the print and leaves the heaters on.
I have tried a few SD cards and even swapped the cable for the SD reader.
I have also noticed that some SD cards lock up the board for a few minutes when they are first inserted.
Anyone have a similar issue or any idea how to fix?
Thanks
Re: RADDS SD card read error
June 16, 2015 04:50PM
Hi edwell,
Please send me your Firmware/ configuration.h.
If you like i make you a stable setup.
If yes, send me a pm.
Have fun
Angelo
RADDS-Shield -> Commercial [max3dshop.org]
June 18, 2015 09:55AM
Thank you I will send a PM with a link to the files now.
September 15, 2016 06:57PM
I am also having the exact same problem, I have radds 1.5 with due using latest repetitive firmware and lcd for radds
Edited 1 time(s). Last edit at 09/15/2016 07:06PM by deaconfrost.
September 16, 2016 02:05PM
I have the same issues, but blame it on the cloned Due board. It has a different reset/erase circuit.
November 16, 2016 11:03AM
but I have the genuine Due, however I sent it back for testing and found to be faulty, waiting for replacement
