smoothie vs duet vs? June 26, 2015 04:20PM |
Re: smoothie vs duet vs? June 26, 2015 04:34PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: smoothie vs duet vs? June 26, 2015 05:13PM |
Re: smoothie vs duet vs? June 26, 2015 05:22PM |
dc42
I like the Duet because it has the better web interface. It doesn't have variable microstepping, it's fixed at 16x, but I can't think of any reason why you would want to use less. The basic board only has 4 drivers on board, so you need to add either the DueX4 or the Duet shield to get more.
Smoothieboard costs more than Duet, however you can get a 5-driver Smoothieboard, which probably makes it cheaper if you want exactly 5 drivers.
Duet firmware configuration is done in the config.g file on the SD card, which is read when the board starts up. So you never need to rebuild the firmware. Smoothieware likewise reads a configuration file at startup.
Re: smoothie vs duet vs? June 26, 2015 07:20PM |
Re: smoothie vs duet vs? June 26, 2015 10:25PM |
Re: smoothie vs duet vs? June 26, 2015 11:49PM |
Re: smoothie vs duet vs? June 27, 2015 12:16AM |
Re: smoothie vs duet vs? June 27, 2015 04:28AM |
woo
I assume duet's interface is same as in Adrians video when introduced Ormerod?
i assume neither hat web cam option on board?
Re: smoothie vs duet vs? June 27, 2015 04:54AM |
Re: smoothie vs duet vs? June 27, 2015 05:21AM |
woo
in speed and power comparission i expect approx. same output from stepper drivers, or am i wrong?
woo
how big are those EMI, will i have problems with it?
woo
about config file, i looked at it and few things are missing, so i assume that not all setup informations are in that file, for example:
temperature settings, homing routine, machine dimensions, etc(if i am looking right files on github.) but that is ok, i still need do some research
woo
i really like that web interface.
Re: smoothie vs duet vs? June 27, 2015 05:32AM |
Re: smoothie vs duet vs? June 27, 2015 07:46AM |
woo
Can anyone screenshot web interface from smoothie?
Re: smoothie vs duet vs? June 27, 2015 08:15AM |
Re: smoothie vs duet vs? June 27, 2015 08:27AM |
Re: smoothie vs duet vs? June 27, 2015 08:51AM |
Re: smoothie vs duet vs? June 27, 2015 08:52AM |
the_digital_dentist
How do you guys use/plan to use the networking with a printer?
I ask because I can't figure out any scenario in which it would be useful unless you've you a bunch of machines on a network and you want to control them from a central point. Am I missing something, or is networking one of those things that people do so they can say they can do it but has little practical value?
You have to be at the machine to change filament, clean the bed, level the bed (most machines), remove the last print, etc. It seems to me that until you can do all that via the network, you may as well just plug in an SD card and hit "go".
Re: smoothie vs duet vs? June 27, 2015 09:34AM |
Re: smoothie vs duet vs? June 27, 2015 10:35AM |
dc42
4. Quite often I am relaxing in one part of the house or the garden while I have a print in progress somewhere else. I use my smartphone to keep an eye on the progress and to know when it has finished.
I have to be at the machine to clean the bed before starting a print, and I like to watch it while the first layer does down. But after than, being able to monitor the progress remotely is useful.
Re: smoothie vs duet vs? June 27, 2015 10:46AM |
JustAnotherOne
dc42
But with the Webinterface you can only see when it is finished. You don't see If it is still printing ok or making a spagetti mess. So I would think it is important to also have a Web Cam for these kinds or remote checks, right?
Re: smoothie vs duet vs? June 27, 2015 11:53AM |
the_digital_dentist
Re: smoothie vs duet vs? June 27, 2015 12:14PM |
Re: smoothie vs duet vs? June 27, 2015 01:23PM |
Re: smoothie vs duet vs? June 28, 2015 12:10PM |
woo
what is quality of replikeo duet board?
Re: smoothie vs duet vs? June 28, 2015 12:15PM |
vreihen
Another annoyance with Smoothie's network interface is that they did not implement common file transfer interface like FTP or SCP. The only file upload options are SIMPLE file transfer protocol (not to be confused with SFTP/Secure FTP) and Plan9. Neither were ever popular on the Internet, and the only reason that I can think of for implementing them and not FTP/SSH/Samba is that these were the only programs that would fit into the available binary space.
Re: smoothie vs duet vs? June 28, 2015 12:52PM |
woo
Can we stick to the topic. Its about 32 bit boards. Thanks!
Re: smoothie vs duet vs? June 28, 2015 12:58PM |
Re: smoothie vs duet vs? June 28, 2015 01:02PM |
JustAnotherOne
I did not want to go off topic. But I Dont think that a 32bit Board should have a Ethernet. A web cam is not possible with these boards and the transfer speed and features of the Web interface are limited due to the limited processing power.
Re: smoothie vs duet vs? June 28, 2015 06:54PM |
dc42
JustAnotherOne
I disagree strongly. The Duet web interface provides fantastic functionality. Upload speed is in excess of 170kbytes/sec, which I find adequate.
Re: smoothie vs duet vs? June 28, 2015 07:56PM |
