Is my duet dead? June 27, 2015 02:34AM |
Re: Is my duet dead? June 27, 2015 04:34AM |
Trix
So i got my first duet board 3 weeks ago and the usb port broke off first time i plugged in the cable so emailed Replikeo and the sent me a replacement which i got today. Now my problem is when i plug the usb in i get the red light on the board next to the usb but my PC does not detect the board nor does it show up in device manager and the end stops do not light up when triggered. I have tried 2 cables and 2 computers with no luck. Did a erase and reset still nothing, Tried diffrent versions drivers nothing, checked to see if any chips get hot by leaving it plugged into the usb for few hours to check for a short everything was nice and cool. So is it broken or am i just missing something?
Update checked pin 1&3 for 5v / 3.3v and im getting 0v on both.
Re: Is my duet dead? June 27, 2015 04:37AM |
Re: Is my duet dead? June 27, 2015 12:31PM |
dc42
If the red light next to the USB port is on, that means 5V power is getting to the board from the USB project e endstop lights should illuminate when the endstop switches are closed. For normally-closed endstop switches (which is the norm for repraps, and is recommended), this is when they are NOT triggered.
Check that you have the endstop switch connectors wired correctly. On the Duet, endstop switches use the outer 2 pins of the 3 pin connector, which is not the same as for RAMPS.
Re: Is my duet dead? June 27, 2015 07:12PM |
Re: Is my duet dead? June 27, 2015 07:35PM |
Re: Is my duet dead? June 27, 2015 11:33PM |
Re: Is my duet dead? June 28, 2015 03:58AM |
Trix
Looks like i am missing d13.
Re: Is my duet dead? June 28, 2015 04:07AM |
Re: Is my duet dead? July 10, 2015 03:29PM |
Re: Is my duet dead? July 10, 2015 04:32PM |
