Ramps 1.4 & Arduino power source July 21, 2015 06:50AM |
Re: Ramps 1.4 & Arduino power source July 21, 2015 07:14AM |
Reprap Wiki
Without D1 installed, or when the 12VIN is not connected, the Arduino gets its power from USB. If you want your kit powered without USB connected you need to solder in D1 OR connect VCC to your PSU.
Re: Ramps 1.4 & Arduino power source July 21, 2015 07:26AM |
Re: Ramps 1.4 & Arduino power source July 21, 2015 08:06AM |
Re: Ramps 1.4 & Arduino power source September 11, 2015 02:52PM |
Re: Ramps 1.4 & Arduino power source September 11, 2015 03:20PM |
Re: Ramps 1.4 & Arduino power source September 11, 2015 04:11PM |
Re: Ramps 1.4 & Arduino power source September 11, 2015 10:13PM |
Re: Ramps 1.4 & Arduino power source September 12, 2015 04:33AM |
Re: Ramps 1.4 & Arduino power source September 12, 2015 10:36AM |
Re: Ramps 1.4 & Arduino power source September 12, 2015 10:50AM |
Re: Ramps 1.4 & Arduino power source September 12, 2015 10:52AM |
As I said above, mine runs fines on 5v, but I wasn't aware of any overheating of Mosfets... what mosfet is that? - Not being sarcastic or anything, but I genuinly would like to know what mosfets? On Ramps or Arduino, and WHY would it overheat?Quote
o_lampe
Check if diode D1 is there on Ramps and mounted in the right direction. #see attached pic
Then you should check if arduinos 5V regulator is working before you can even think of doing any mods to Ramps or LCD.
Don´t feed 5V to arduinos barrel connector as proposed before. The regulator needs at least 7V input voltage to work properly. With only 5V input the risk of overheating MOSFET is bigger.
-Olaf
Re: Ramps 1.4 & Arduino power source September 15, 2015 04:27PM |
Re: Ramps 1.4 & Arduino power source September 15, 2015 04:45PM |
