wrong heatsink in parts list?
Posted by owad
October 03, 2007 12:38PM
I think the heatsink in the parts generator is wrong. Mouser part #532-566010B03400G is a "Vertical mount, slide-on with tabs" heatsink. It's rated for 11.5
Re: wrong heatsink in parts list?
October 03, 2007 03:08PM
what part was this specified for?
we have two types of heatsinks in the BOM: big and small. that one is the 'big' one which is intended to be mounted on the L298N. the 'small' one is this: [www.mouser.com] and is intended to be mounted on the TIP110's.
just looking for a bit more info...
October 03, 2007 04:09PM
In the part list it's called the "big heat sink". That page links to Mouser part #532-566010B03400G. . If you download page 1702 of the mouser catalog, you'll see it in Figure W. The heat sink is designed to snap in rather than be screwed on, and doesn't match any part that I can find.
October 03, 2007 05:21PM
ah, i see. i'll change the big heatsink part to be this new part you've found. thanks!
October 03, 2007 05:30PM
i do think we might need a bit bigger one. i'm not really too knowledgable about the heatsink requirements, but that one is designed for a TO-220 housing, whereas the L298 is a MULTIWATT-15 housing. i also think it puts out more heat than the TIP120's, so we might want to beef it up a bit.
October 03, 2007 06:42PM
Use MOSFETS and ditch the heatsinks!
October 03, 2007 08:57PM
> It's rated for 11.5
October 03, 2007 09:22PM
How about the 532-7023B-MTG?
Channel style w/folded back fins, TO-220, Multiwatt
Vertical
Black anodized
Solder Tabs
4.4
Anonymous User
October 03, 2007 10:04PM
owad Wrote:
> > It's rated for 11.5
October 04, 2007 11:27AM
The SureStep motors are rated at 2.8 A/phase.
I'm curious to hear any opinions of the 532-7023B-MTG, as I'd like to order some shortly, and I'm not at all certain if it's appropriate.
As for the solder tabs, they're in a little pile of dust beside my grinder.
Anonymous User
October 04, 2007 11:46AM
The L298 is only rated for 2A per phase. It *might* be able to take 2.8A if you were stepping fast, but you'd have to cut the power back as soon as you stopped stepping. The stock firmware doesn't do anything like this, so if you're using that, you'll need to run it at <2A all the time (either by lowering the torque setting or adding resistors)
October 11, 2007 12:40PM
I have a surestep running at 70% torque with the 532-7023B-MTG heatsinks and it seems to be holding up pretty well (Z axis).
The heatsink is very close to touching the diodes, though.
