Duet board seems to have burnt out - is there a procedure for checking? September 07, 2015 05:07PM |
Re: Duet board seems to have burnt out - is there a procedure for checking? September 07, 2015 06:07PM |
Re: Duet board seems to have burnt out - is there a procedure for checking? September 07, 2015 08:48PM |
Re: Duet board seems to have burnt out - is there a procedure for checking? September 08, 2015 07:23AM |
Re: Duet board seems to have burnt out - is there a procedure for checking? September 08, 2015 08:43AM |
Re: Duet board seems to have burnt out - is there a procedure for checking? September 08, 2015 10:04AM |
patrickrio
the teflon was melted off my thermistor where the screw holds it in place. It looks like I got runaway heat that then caused the short out to the aluminum block. Not sure how my heater wire contacted the aluminum.
2 questions:
1. how do I get runaway heat like that?
2. is there a way to get the heater block to conduct electricity to the aluminum on accident without the wire touching? The wires seemed far from the block....
