Re: Duet 0.8.5 z probe connector October 13, 2015 09:10PM |
Re: Duet 0.8.5 z probe connector October 14, 2015 03:11AM |
Re: Duet 0.8.5 z probe connector October 14, 2015 08:30AM |
Re: Duet 0.8.5 z probe connector October 14, 2015 09:20AM |
Re: Duet 0.8.5 z probe connector October 14, 2015 04:18PM |
Re: Duet 0.8.5 z probe connector October 14, 2015 05:47PM |
Re: Duet 0.8.5 z probe connector October 15, 2015 09:22AM |
Re: Duet 0.8.5 z probe connector October 15, 2015 03:18PM |
Re: Duet 0.8.5 z probe connector October 15, 2015 03:22PM |
Re: Duet 0.8.5 z probe connector October 17, 2015 09:03AM |
Re: Duet 0.8.5 z probe connector October 17, 2015 10:05AM |
Re: Duet 0.8.5 z probe connector October 23, 2015 11:04PM |
dc42
Yes I would like to wrap the messages to at least 2 lines, but I have more pressing work on the PanelDue firmware, in particular I have two users who need support for more than two extruders.
Re: Duet 0.8.5 z probe connector October 24, 2015 12:32AM |
Re: Duet 0.8.5 z probe connector October 24, 2015 01:36AM |
626Pilot
dc42
I migrated from Smoothie to the Duet platform because it has hardware support for 3+ extruders. Is that not working yet, and if not, do you have a rough ETA?
Re: Duet 0.8.5 z probe connector October 24, 2015 02:39AM |
Re: Duet 0.8.5 z probe connector October 24, 2015 06:22AM |
WZ9V
626Pilot, I'm considering a similar migration. How has the Duet and DC42 firmware branch been working for you?
dc42
PanelDue currently provides controls and status for only the first 2 hot ends. The next PanelDue firmware version will support 4 hot ends on a 4.3 inch screen, and 6 hot ends on a 5 or 7 inch screen.
Re: Duet 0.8.5 z probe connector October 24, 2015 07:51AM |
626Pilot
WZ9V
I did a comprehensive Duet vs. Smoothie comparison here, earlier today: here
If you want to drive a big CNC machine with its own high-torque stepper drivers, Smoothie has pin connectors that you can use to bypass the built-in drivers, so you can use Gecko drives or whatever you want. Duet lacks this feature - but again, if you're here, you probably only care about running a low-current delta printer such as the Rostock MAX.
You can get the Duet 0.8.5, DueX4, and PanelDue from a single vendor in the UK that will ship to the US reasonably quick. I got mine in about a week. Since all three parts can be had from the same vendor, I consider this a fully-integrated hardware solution.
Duet doesn't allow you to mount the SD card over USB at all, which is an inconvenience. However, you can edit over FTP, or upload over the web interface. I don't know whether it's faster than USB transfers to Smoothie. Someone else can chime in on that.
