Re: RADDS work now stable with RepRap Firmware October 21, 2015 08:49AM |
Re: RADDS work now stable with RepRap Firmware October 21, 2015 09:10AM |
VDX
Hi Pieter,
have you tried with the images for "Debian Wheezy armHF" or "Ubuntu 12.04 LTS" ?
Re: RADDS work now stable with RepRap Firmware October 21, 2015 10:17AM |
filipeCampos
Next printscreen is pronterface printing from an SD card, in the console it output no stop "Not SD printing", this is some bug?
Re: RADDS work now stable with RepRap Firmware October 21, 2015 11:19AM |
dnewman
filipeCampos
FWIW, I opened an issue on this yesterday when I happened across it by chance in the source code,
https://github.com/dc42/RepRapFirmware/issues/15
Re: RADDS work now stable with RepRap Firmware October 21, 2015 05:23PM |
Re: RADDS work now stable with RepRap Firmware October 21, 2015 06:10PM |
filipeCampos
Thanks.
The new version correct the bug, but now is outputting lots of "SD Printing".
I checked the class GCodes to understand why is prints the same string during the print and the code is only processing to an request made. The problem is not the firmware but the successive request made my pronterface.
filipeCampos
I do not know the reprap firmware, so far i only see the class GCodes by curiosity, but.. is a mess...
I not where to juggle or criticize, but this class have a lot of room to improve and need an major refactoring. There are function with more of 100 lines, lots of switch with other switch inside, no use of global variable like NEW_LINE = "\n" instead is repeated all over the code, all the string message must be put in other file and use set was a variable, etc..
The way the class was structured is very difficult to read and support.
Re: RADDS work now stable with RepRap Firmware October 21, 2015 07:00PM |
Re: RADDS work now stable with RepRap Firmware October 22, 2015 08:31AM |
Re: RADDS work now stable with RepRap Firmware October 22, 2015 09:02AM |
Re: RADDS work now stable with RepRap Firmware October 22, 2015 01:20PM |
Re: RADDS work now stable with RepRap Firmware October 22, 2015 04:29PM |
Re: RADDS work now stable with RepRap Firmware October 22, 2015 05:23PM |
Re: RADDS work now stable with RepRap Firmware October 22, 2015 05:29PM |
Re: RADDS work now stable with RepRap Firmware October 25, 2015 02:37PM |
Re: RADDS work now stable with RepRap Firmware October 25, 2015 03:59PM |
Re: RADDS work now stable with RepRap Firmware October 25, 2015 04:20PM |
Re: RADDS work now stable with RepRap Firmware October 25, 2015 06:42PM |
Re: RADDS work now stable with RepRap Firmware October 25, 2015 07:31PM |
WZ9V
When using RADDs with a Due do you get the faster USB with h/w flow control similar to what the Duet has?
Re: RADDS work now stable with RepRap Firmware October 25, 2015 09:22PM |
WZ9V
Re: RADDS work now stable with RepRap Firmware October 26, 2015 05:48AM |
Re: RADDS work now stable with RepRap Firmware October 26, 2015 10:30AM |
filipeCampos
I have noticed the upload of the firmware using the native usb is faster that using the programming one.
filipeCampos
Normally in the others firmware is necessary to indicate the velocity of the communication, with the native usb this velocity is used? or it will be used the speed of the protocol USB 2.0?
Re: RADDS work now stable with RepRap Firmware October 26, 2015 10:44AM |
dnewman
filipeCampos
Unless you will be downloading the firmware many times per day, does this really matter to you? And with the RADDS board, you can use either USB port. However, the physical design of the RADDS board will make it difficult for you to reach the ERASE button. If you use the native port to download firmware, then you will need some form of access to that button.
Re: RADDS work now stable with RepRap Firmware October 26, 2015 11:27AM |
filipeCampos
I have done several times the upload of the firmware with the native usb and without using the reset button.The same happens if you upload repetier firmware using the arduino IDE.
Why are you saying is necessary to push the erase button?
Re: RADDS work now stable with RepRap Firmware October 26, 2015 11:44AM |
Re: RADDS work now stable with RepRap Firmware October 26, 2015 12:13PM |
Re: RADDS work now stable with RepRap Firmware October 26, 2015 02:17PM |
filipeCampos
This is the reason i not sure why you are referring the erase button. I have miss reading or missing something?
Re: RADDS work now stable with RepRap Firmware October 26, 2015 02:44PM |
Re: RADDS work now stable with RepRap Firmware October 26, 2015 06:15PM |
Re: RADDS work now stable with RepRap Firmware October 27, 2015 05:57PM |
Re: RADDS work now stable with RepRap Firmware October 27, 2015 08:19PM |
filipeCampos
I receive today the lcd send by angelo, installed but is not working with the reprapfirmware. On repetier the radds lcd works fine.
This reprapFirmware porting supports the radds 20x4 lcd? It is necessary to make some configuration?
