Re: RADDS work now stable with RepRap Firmware June 20, 2016 01:49PM |
dnewman
I've uploaded a 1.13a-dc42-radds.bin file. I've temporarily disabled the core part of the new MCU temp monitoring code. Namely the lines
Re: RADDS work now stable with RepRap Firmware June 20, 2016 01:52PM |
dc42
If you have two Z motors connected in parallel, try connecting them in series instead. Connecting them in parallel is only a good idea if they are low-current high- (relatively) voltage motors.
Re: RADDS work now stable with RepRap Firmware June 20, 2016 01:54PM |
Re: RADDS work now stable with RepRap Firmware June 20, 2016 02:32PM |
AK_Eric
@Nandox7 :
With my 12v setup, I use SD6128's, and I have them dialed in about .75v, they behave well there.
I recently tried swapping to the RAPS128's, and that same voltage was super under-powered, I had to bump it up to around 1.1v to get them to move.
Panucatt SD6128: current limit = 2 x Vref = 1.5A current limit @ Vref=0.75V RAPS128: current limit = 0.9125 x Vref = 1.0A current limit @ Vref=1.1V
Re: RADDS work now stable with RepRap Firmware June 22, 2016 10:11AM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 10:30AM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 12:32PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 01:13PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 02:11PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 02:18PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 02:53PM |
ICanBeRobot
Having dealt with modems and other serial devices quite a bit, most actually expect \r\n which is why minicom expects that. Other firmwares I have used send both.
Anyways I did that and now I get:
[imgur.com]
and stays there.
If I type random keys I eventually get this error, "Error: G-Code buffer length overflow" but I cannot actually issue Gcode commands and get any results back.
Re: RADDS work now stable with RepRap Firmware June 22, 2016 04:06PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 04:44PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 06:54PM |
Re: RADDS work now stable with RepRap Firmware June 22, 2016 10:55PM |
Re: RADDS work now stable with RepRap Firmware June 23, 2016 12:55PM |
Re: RADDS work now stable with RepRap Firmware June 23, 2016 01:40PM |
o_lampe
To bad David skipped the dc42 part of the .bin file name.
How are we users suppose to know it's made for delta or CoreXY or Cartesian?
Re: RADDS work now stable with RepRap Firmware June 24, 2016 08:55AM |
Re: RADDS work now stable with RepRap Firmware June 24, 2016 01:26PM |
o_lampe
Ah,
didn't know that. Always thought David's work was delta_only because of the different math behind the XYZ towers...
Re: RADDS work now stable with RepRap Firmware June 25, 2016 12:57PM |
Re: RADDS work now stable with RepRap Firmware June 25, 2016 03:12PM |
Re: RADDS work now stable with RepRap Firmware June 26, 2016 05:52AM |
Re: RADDS work now stable with RepRap Firmware June 26, 2016 04:32PM |
Re: RADDS work now stable with RepRap Firmware June 26, 2016 11:03PM |
Re: RADDS work now stable with RepRap Firmware June 27, 2016 06:04AM |
Nandox7
Thanks everyone for their input.
@dc42, how would I connect them in series? The board already has the pin headers to plug the 2x Z steppers.
Re: RADDS work now stable with RepRap Firmware June 27, 2016 11:31AM |
C-A+ <--------> S1-A+ | \---> S2-A+ /---> S2-A- | C-A- <--------> S1-A- C-B+ <--------> S1-B+ | \---> S2-B+ /---> S2-B- | C-B- <--------> S1-B-
C-A+ <--------> S1-A+ /--> S1-A- | \--> S2-A+ C-A- <--------> S2-A- C-B+ <--------> S1-B+ /--> S1-B- | \--> S2-B+ C-B- <--------> S2-B-
F1 <--------> M1-1 /--> M1-2 | \--> M2-1 F2 <--------> M2-2 F3 <--------> M1-3 /--> M1-4 | \--> M2-3 F4 <--------> M2-4
Re: RADDS work now stable with RepRap Firmware June 27, 2016 02:57PM |
GroupB
I was looking at arduino.org did you guy notice this new board [www.arduino.org]
Re: RADDS work now stable with RepRap Firmware June 27, 2016 09:59PM |
Re: RADDS work now stable with RepRap Firmware June 28, 2016 12:09AM |
Re: RADDS work now stable with RepRap Firmware June 28, 2016 12:39AM |
AK_Eric
Just an FYI my update to 1.13a-radds went off without a hitch: I used the "popsicle stick" method to access the reset button... and hopefully with this update I'll never have to do that again
