Re: RADDS work now stable with RepRap Firmware July 02, 2016 10:32AM |
o_lampe
The RADDS version of the config.g has a non defined parameter:
M574 X2 Y2 Z2 P1
I guess it should be S1 or S0?
But either way, I can't make my endstops talk to RRF. Defined as S1 they always show " at max endstop"; defined as S0 they always show "not triggered " when I send M119 command.
Re: RADDS work now stable with RepRap Firmware July 02, 2016 10:34AM |
o_lampe
Where would I put my z-probe connectors? On a duet it'd be the E0 endstop, but I've found no dokumentation about it on doku.radds.....
Searching the forum for [radds z-probe (all words)] showed each comment where radds was included.
WTF does all words mean then?
Re: RADDS work now stable with RepRap Firmware July 02, 2016 11:26AM |
Re: RADDS work now stable with RepRap Firmware July 02, 2016 11:44AM |
shofman
Dnewman, can i use your 1.13a firmware with DVR8825 steppers ?
Should I replace them by raps128 ?
Thanks
Re: RADDS work now stable with RepRap Firmware July 02, 2016 11:59AM |
Re: RADDS work now stable with RepRap Firmware July 02, 2016 12:18PM |
shofman
What is the maximum step rate that I can use ?
Re: RADDS work now stable with RepRap Firmware July 02, 2016 12:25PM |
Re: RADDS work now stable with RepRap Firmware July 02, 2016 03:22PM |
Re: RADDS work now stable with RepRap Firmware July 02, 2016 06:28PM |
dc42
I have just released version 1.14 of RepRapFirmware for the Duet and Duet WiFi, with a new T parameter to the M569 command to extend the step pulse timings. Some of the changes are very hardware-dependent, so somebody will need to do a little work on the code before it can be built for RADDS.
Re: RADDS work now stable with RepRap Firmware July 02, 2016 06:41PM |
Re: RADDS work now stable with RepRap Firmware July 02, 2016 06:52PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 02:41AM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 03:01AM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 01:21PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 01:26PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 02:27PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 03:06PM |
shofman
Dnewman and DC42, is there any chance to have in the future only one RRF version, and only have to modify some specific parameters in a file to use the selected hardware ?
Re: RADDS work now stable with RepRap Firmware July 03, 2016 04:44PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 05:01PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 05:11PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 08:26PM |
Re: RADDS work now stable with RepRap Firmware July 03, 2016 09:36PM |
dc42
As Dan says, there are just too many differences. We have a separate build of RepRapFirmware for the Duet WiFi too.
I'm not saying it is impossible, it's just not very practical.
Re: RADDS work now stable with RepRap Firmware July 04, 2016 01:19PM |
Re: RADDS work now stable with RepRap Firmware July 04, 2016 01:29PM |
shofman
Hi Dnewman,
What's new on your 1.14 firmware ?
Re: RADDS work now stable with RepRap Firmware July 04, 2016 01:32PM |
Re: RADDS work now stable with RepRap Firmware July 04, 2016 03:27PM |
Re: RADDS work now stable with RepRap Firmware July 04, 2016 03:54PM |
Re: RADDS work now stable with RepRap Firmware July 04, 2016 04:03PM |
Re: RADDS work now stable with RepRap Firmware July 04, 2016 06:57PM |
Re: RADDS work now stable with RepRap Firmware July 04, 2016 09:54PM |
turboproc
This is weird: loading the DUE board with one of the SdFat example programs immediately shows all the details of the SD card. Took more time to upload the program than to run it.
Is it possible to activate a debugging log in the SPI or Storage part of the code? Haven't crawled yet through the CoreNG source yet. Presume it is somewhere there.
sys
config.g
