Re: RADDS work now stable with RepRap Firmware July 08, 2016 06:21AM |
Re: RADDS work now stable with RepRap Firmware July 08, 2016 08:40AM |
shofman
Ok thanks.
About steppers : is there any interest to use 1/64, 1/128 or 1/256 configuration ?
My motors are : 17HS16-2004S
Re: RADDS work now stable with RepRap Firmware July 08, 2016 09:29AM |
Re: RADDS work now stable with RepRap Firmware July 08, 2016 01:45PM |
shofman
Thanks Dnewman... I will stay with M569 because it just works.
About the RAPS128 : is there any interest to use 1/64 or 1/128 configuration ?
Re: RADDS work now stable with RepRap Firmware July 08, 2016 09:54PM |
Re: RADDS work now stable with RepRap Firmware July 08, 2016 10:05PM |
deaconfrost
the user guide says to power RADDS by 24V the diode used in the default 12V setup have to be
replaced by three Zener diodes (4 V and 1.3W).
is 4.3v 1.3w ok?
Re: RADDS work now stable with RepRap Firmware July 09, 2016 06:48AM |
shofman
Your motors are 0.9°, and mine are 1.8°
So if i use 1/32 and you use 1/16, we are in the same configuration ?
So I suppose this kind of tune is not very important ?
Re: RADDS work now stable with RepRap Firmware July 09, 2016 07:54AM |
dnewman
deaconfrost
is 4.3v 1.3w ok?
Somewhere you should also find amongst the RADDS documents that you do not need to do that for the v1.5 RADDS electronics. That's my recollection at least. I use 25V with my v1.5 boards and I've never made that mod.
Re: RADDS work now stable with RepRap Firmware July 09, 2016 03:53PM |
Re: RADDS work now stable with RepRap Firmware July 11, 2016 07:30AM |
Re: RADDS work now stable with RepRap Firmware July 11, 2016 11:37AM |
Re: RADDS work now stable with RepRap Firmware July 12, 2016 12:30AM |
AK_Eric
@GroupB : My bot is core-xy, and the build volume and offsets are correct in S3D. Same settings I've used in there for Marlin, Repetier, and now RRF.
@DC42 : My endstops are 'normally open' microswitches: If I depress the X-endstop and enter a M119 I get
SENT: M119 READ: Endstops - X: at min stop, Y: not stopped, Z: not stopped, Z probe: not stoppedAnd the endstop is definitely hit before anything else.
@truboproc : My config.g looks very similar.
So, it's the morning: I power my bot on and issue:
G28 X0 Y0
And it works just fine, as expected. But, if I start a print, if I execute that at the end of my print in gcode, or if I execute that over a serial connection at the end of a print, it'll smash.
Below is the header and the footer of the gcode that causes it, if anyone can spot a problem?
Re: RADDS work now stable with RepRap Firmware July 12, 2016 01:58AM |
Re: RADDS work now stable with RepRap Firmware July 12, 2016 04:26AM |
Re: RADDS work now stable with RepRap Firmware July 12, 2016 06:26PM |
Re: RADDS work now stable with RepRap Firmware July 13, 2016 12:33PM |
Re: RADDS work now stable with RepRap Firmware July 13, 2016 03:35PM |
Re: RADDS work now stable with RepRap Firmware July 14, 2016 10:44AM |
Re: RADDS work now stable with RepRap Firmware July 14, 2016 06:55PM |
Re: RADDS work now stable with RepRap Firmware July 15, 2016 06:08AM |
GroupB
If the 1.14 modification is whats they did for my special 1.09r firmware , im sure its will work ok
Re: RADDS work now stable with RepRap Firmware July 15, 2016 09:50AM |
Re: RADDS work now stable with RepRap Firmware July 15, 2016 02:21PM |
CthulhuLabs
dc42 - Thanks was wondering how to configure these. Does having an increased pulse effect over all RRF performance in any way?
Re: RADDS work now stable with RepRap Firmware July 15, 2016 02:57PM |
Re: RADDS work now stable with RepRap Firmware July 15, 2016 03:52PM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: RADDS work now stable with RepRap Firmware July 15, 2016 04:13PM |
Wurstnase
Yes. Become really messy. I made the optimization for DRV8825. But you can't do the same in RRF. Marlin4Due reaches 100kHz in Single-Stepping. With that you can start a step before the calculations and end the steps after them. Afaik RRF doing something like that, but the calculations are much more expensive there and you can only reach 15kHz?!? or so. To get full speed you step any stepper 2 or more time after any calculation. And with a SAM3x this is too fast for the DRV8825. The driver needs min. 2μs high signal.
Re: RADDS work now stable with RepRap Firmware July 15, 2016 05:03PM |
Re: RADDS work now stable with RepRap Firmware July 16, 2016 10:35AM |
deaconfrost
Wurstnase
what do you mean by messy? the code itselfor the numbers of dev on it??
Re: RADDS work now stable with RepRap Firmware July 16, 2016 01:38PM |
Wurstnase
deaconfrost
Wurstnase
I only took a look inside the stepper.cpp. This is not maintainable anymore.
Re: RADDS work now stable with RepRap Firmware July 17, 2016 03:28AM |
deaconfrost
wurstnase
deaconfrost
thats not good
Re: RADDS work now stable with RepRap Firmware July 17, 2016 04:43PM |
Wurstnase
deaconfrost
wurstnase
deaconfrost
thats not good
Maybe a bit harsh. Kimbra should be able to read the code.
