Re: RADDS work now stable with RepRap Firmware July 18, 2016 12:57PM |
Re: RADDS work now stable with RepRap Firmware July 18, 2016 04:13PM |
Re: RADDS work now stable with RepRap Firmware July 19, 2016 08:30AM |
Re: RADDS work now stable with RepRap Firmware July 19, 2016 08:33AM |
Eric, do you know if Octoprint will upload config files in the future, like the Duet Web interface can do ?Quote
AK_Eric
I have that config right now (well Dan's RAADS port of the dc42 firmware) working successfully. You have to get a special cut of Octoprint for it to work with RRF though, and install a custom Octoprint plugin. I outline this here:
[www.akeric.com]
Re: RADDS work now stable with RepRap Firmware July 19, 2016 10:55AM |
shofman
AK_Eric
[www.akeric.com]
Re: RADDS work now stable with RepRap Firmware July 19, 2016 11:07AM |
Re: RADDS work now stable with RepRap Firmware July 19, 2016 11:37AM |
shofman
AK_Eric
[www.akeric.com]
Re: RADDS work now stable with RepRap Firmware July 20, 2016 11:41AM |
AK_Eric
[www.akeric.com]
Re: RADDS work now stable with RepRap Firmware July 20, 2016 12:07PM |
I can't use the programming port at all (independent from Octoprit or otherwise), I have to use the native port for all things RRF. When I used Repetier I could use the programming port, fyi.Quote
o_lampe
AK_Eric
[www.akeric.com]
Thanks for sharing Eric
If I understand it correctly, this dev-version doesn't exactly solve the native_port_problem, but uses the programming port instead? Or was it just your personal decision to use it?
Re: RADDS work now stable with RepRap Firmware July 20, 2016 12:36PM |
Re: RADDS work now stable with RepRap Firmware July 30, 2016 07:14PM |
shofman
Hi everyone,
About Z probe configuration : what is the maximum voltage that can accept the PWM3 pin ?
5V or 3.3 ?
And what is the minimum required current to have a good signal ? 1mA is it enough ?
I will use a capacitive sensor Ljc18a3-h-z/bx.
Thanks
Re: RADDS work now stable with RepRap Firmware July 31, 2016 04:58AM |
Re: RADDS work now stable with RepRap Firmware July 31, 2016 07:16AM |
Re: RADDS work now stable with RepRap Firmware August 11, 2016 06:21AM |
Re: RADDS work now stable with RepRap Firmware August 11, 2016 10:23AM |
shofman
Hi everyone,
DC42 has made a new version 1.15 beta 6 :
Changelog :
Add support for second SD card on SPI bus for Duet WiFi including
I have tried to connect a Micro SD SPI module with no luck. (the CD pin was not used)
When the module is connected, the RADDS can not read the SD card, even in the integrated slot.
Re: RADDS work now stable with RepRap Firmware August 11, 2016 10:55AM |
Re: RADDS work now stable with RepRap Firmware August 11, 2016 11:02AM |
Re: RADDS work now stable with RepRap Firmware August 11, 2016 11:03AM |
Re: RADDS work now stable with RepRap Firmware August 11, 2016 11:26AM |
shofman
Sorry but I don't know how to do this...
Re: RADDS work now stable with RepRap Firmware August 11, 2016 03:24PM |
Re: RADDS work now stable with RepRap Firmware September 08, 2016 05:33PM |
Re: RADDS work now stable with RepRap Firmware September 09, 2016 02:52AM |
AK_Eric
Random question: Is the concept of 'Z babystepping' possible in RRF? I recently encountered a bed level issue where it would have been really nice to manually tune the z-height during the first layer. Or is something similar available via a custom macro?
thanks!
Re: RADDS work now stable with RepRap Firmware September 14, 2016 11:08PM |
Re: RADDS work now stable with RepRap Firmware September 15, 2016 03:46AM |
Re: RADDS work now stable with RepRap Firmware September 15, 2016 01:28PM |
Re: RADDS work now stable with RepRap Firmware September 15, 2016 11:58PM |
Re: RADDS work now stable with RepRap Firmware September 17, 2016 12:15AM |
SENT: M997 S0 SENT: M105 READ: Heat class exited. READ: Move class exited. READ: Move class exited. READ: Updating main firmware SENT: M105 WARNING: Device unplugged while connected to port
Re: RADDS work now stable with RepRap Firmware September 17, 2016 12:47AM |
Re: RADDS work now stable with RepRap Firmware September 17, 2016 02:17AM |
Re: RADDS work now stable with RepRap Firmware September 17, 2016 08:22AM |
