Re: RADDS work now stable with RepRap Firmware July 12, 2017 10:46AM |
Re: RADDS work now stable with RepRap Firmware July 13, 2017 12:52AM |
Re: RADDS work now stable with RepRap Firmware July 13, 2017 03:40AM |
Re: RADDS work now stable with RepRap Firmware July 16, 2017 09:48AM |
Micktol
I just tried beta6, it does not work.
Re: RADDS work now stable with RepRap Firmware July 17, 2017 12:48AM |
Re: RADDS work now stable with RepRap Firmware July 17, 2017 02:15AM |
Re: RADDS work now stable with RepRap Firmware July 18, 2017 09:55AM |
Re: RADDS work now stable with RepRap Firmware July 18, 2017 03:50PM |
Re: RADDS work now stable with RepRap Firmware July 18, 2017 04:44PM |
Re: RADDS work now stable with RepRap Firmware September 16, 2017 07:59PM |
Re: RADDS work now stable with RepRap Firmware September 17, 2017 02:53AM |
Re: RADDS work now stable with RepRap Firmware September 17, 2017 02:56AM |
Re: RADDS work now stable with RepRap Firmware September 19, 2017 12:07AM |
(going to presume you know this already, but for due diligence) :Quote
dc42
The Pins_RADDS.h file in the source code indicates that there are only 4 active endstop inputs in the RADDS build. If you can tell me the pin numbers of all 6 endstop inputs, I can add the missing ones if those pins are not already used for something else e.g. the Z probe.
I thought that's what I had done: Are you saying there's a different pin on RADDS other than D39 / E0_AXIS for the z-probe?Quote
dc42
If you connect your inductive probe to the Z probe input instead, you could free up the E0 input.
Re: RADDS work now stable with RepRap Firmware September 19, 2017 06:26AM |
Re: RADDS work now stable with RepRap Firmware September 19, 2017 12:29PM |
Re: RADDS work now stable with RepRap Firmware September 20, 2017 02:26AM |
Re: RADDS work now stable with RepRap Firmware September 25, 2017 11:46PM |
Re: RADDS work now stable with RepRap Firmware December 11, 2017 12:25PM |
Re: RADDS work now stable with RepRap Firmware December 11, 2017 05:55PM |
Re: RADDS work now stable with RepRap Firmware December 12, 2017 03:43PM |
Re: RADDS work now stable with RepRap Firmware December 14, 2017 06:21PM |
Re: RADDS work now stable with RepRap Firmware December 18, 2017 11:27AM |
Re: RADDS work now stable with RepRap Firmware December 18, 2017 12:32PM |
Re: RADDS work now stable with RepRap Firmware December 24, 2017 03:27PM |
Re: RADDS work now stable with RepRap Firmware December 24, 2017 06:44PM |
Re: RADDS work now stable with RepRap Firmware January 11, 2018 02:21PM |
Re: RADDS work now stable with RepRap Firmware January 12, 2018 02:37AM |
Re: RADDS work now stable with RepRap Firmware January 14, 2018 08:33AM |
Re: RADDS work now stable with RepRap Firmware January 14, 2018 05:15PM |
FTheta
Thank you David, it woks perfectly. I just had to raise the M570 P parameter over 45, to avoid the heating faliure.
I understand completly why you drop the RADDS support, but I'm a bit disappointed becouse RADDS+DUE was a budget option to bring RepRap FW to low-end printers. Cheap deltas benefit the most from it.
FTheta
Do you plan to release cheaper (mini?) board?
Re: RADDS work now stable with RepRap Firmware February 06, 2018 11:55PM |
