VDX
Re: RADDS work now stable with RepRap Firmware
February 14, 2019 12:39PM
... you're moving speeds are way too fast, so the motor stalls ... reduce them by factor 10x and try again ...
Viktor
February 14, 2019 01:06PM
Thanks for the suggestion, but I doubt it's that. It's been working fine under version 1.21 with the same config files (at a relatively modest 3000mm/min), and is OK again now that I've reverted back. But when I have another go at 2.02 I'll try lowering the homing speed to see if that helps.
VDX
February 14, 2019 01:38PM
... ist the "steps per mm" setting correct?
Viktor
February 14, 2019 02:53PM
Yes, steps/mm and every other setting are the same as they were under the 1.21 firmware, which is working OK. Are you successfully running RRF 2.02 on RADDS?
VDX
February 14, 2019 05:44PM
... no, I'm using Marlin4Due and Marlin2.0 ...
Viktor
