Duet extruder does not work
Posted by trgtylcnky
October 24, 2015 07:34AM
I am using RepRapPro Duet 0.8.5 on my custom printer. I am using Pronterface. When I want to calibrate extruder by "Extrude" button on interface, It said no tool selected. I send T0 command and M302 P0 commands. Now It says "Extruding 1 mm of filament" but nothing happens.
Moreover, when I set the hotend temperature to 240, nothing happens. "E0 Heat" led does not light.
I think something is wrong in my configurations but I could not find anything.
Re: Duet extruder does not work
October 24, 2015 08:46AM
If you attach your config.g file then we can check it for errors.
By default, cold extrusion is prevented. Send M302 P1 to enable it, not M302 P0.
