Connectivity to board question
Posted by [email protected]
December 28, 2015 09:10PM
I have the Duet 0.8.5 with and am plugging in an extruder motor i got off of eBay. [www.ebay.com]
The extruder has a previously installed wiring plug with color coding in the order: blue, red, green, black. I found on the wiki for duet, however, that the wiring for the duet 0.8.5 is red, blue, green, black. [reprap.org]
My question is: Are those blue and red wires interchangeable or should i rewire it? Thanks.
Re: Connectivity to board question
December 29, 2015 09:54AM
You can plug it in as it is. If the motor turns the wrong way, either power off and reverse the connector, or change it using the M569 command in config.g.
