Help with extruder stepper
September 28, 2010 10:59AM
I'm using wades geared extruder with a nema 17 stepper. The temperature sensor works along with the heated barrel. How would i test the stepper on the extruder to make sure it works.
Re: Help with extruder stepper
September 28, 2010 12:42PM
All stepper motors are the same, so you can connect the extruder stepper motor to the stepper motor driver board of one of the axes.
September 28, 2010 01:55PM
It works fine when connected to one of the axis. When its connected to the extruder, i can turn the stepper manually which causes the power light to come on (like the other axis). When I press the extrude button, nothing happens. Will it only extrude when the heater is at a certain temp? Is there a way i can force the stepper when it's attached to the extruder?
September 28, 2010 04:29PM
I should mention that i'm using the techzone v3 electronics. [reprap.org]
September 30, 2010 12:39AM
I think I have it working. If i turn the extruder on the extruder motor truns for about 5 seconds and then holds with torque. Press it off does the same thing. Is this normal behavior?
September 30, 2010 03:01AM
Yes.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
