Max endstop issue
Posted by reece.arnott
Max endstop issue
November 22, 2007 01:28AM
I have all my opto-endstops working... except for one!
The max endstop on my z controller board (v1.2.1) is not working i.e. it never stops the motors. If the opto-endstop is replaced by a known good one it still doesn't work. Even when you just insert and take off the jumper it still doesn't work.
The min works just fine. I was thinking of swapping the chips around to see if its an issue with the z chip firmware but thought it was more likely I would cause more issues with bent pins getting the chips in and out. So I thought I'd try reviewing the electronics in situ first.
Of course I have no idea where to start so I thought I'd cry for help...
HELP!
What should I be looking for? As I've had a few issues with getting the chips properly inserted in the first place could this be an issue with a bent pin on the chip and if so, which pin?
VDX
Re: Max endstop issue
November 22, 2007 02:52AM
Hi Reece,
... first, measure the voltage at all the pins of a 'good' endstop and then at the Z-max - this should eliminate simple supply-malfunctions ...
Then try to activate the opto-switch with a thin black sheet of cartonage or plastic (paper eventually didn't work), to see, if it basically works ...
And then go through the wires, to check if there's a shortcut or break anywere ...
Last step would be debugging the software ...
Viktor
November 23, 2007 12:22AM
Fixed it.
As I suspected it was a bent pin on one of the corners of the chip. I just took the chip out, carefully unbent it and carefully reseated the chip. I probably should have taking note of which pin it was but I didn't and now I can't tell. Oh, well.
